Results 1 to 8 of 8
    Jul 2010
    Default Radio code location in memory dump from Alpine MF2199
    After analyzing the dump thanks to the response from SITI I found that the radio code was located in address 00000010 which is the second line from the top. In my situation it was 73570.
    First five lines of the memory:
    28 98 98 07 17 00 00 98 00 FF FF FF FF FF FF FF
    07 35 70 43 07 35 70 43 F8 CA 8F BE 0B 00 FF FF
    03 44 04 59 03 05 02 01 04 D2 43 20 17 00 00 00
    A8 D2 42 20 07 00 00 00 CA D2 41 60 56 00 00 00
    75 D1 33 20 01 00 00 00 00 D1 42 20 02 00 00 00
    So, if anyone needs to find the code first try to read the memory dump from your radio. It is a good chance that you will find it where I did in my radio.
  2. The Following User Says Thank You to zdzich For This Useful Post:
    Dr Alex (9th February, 2020)
  3. #2
    bonus2010's Avatar
    Mar 2010
    Scotland
    Thanks for sharing this information. The fact is, I was
    very near to agreeing with fellow member that it was a
    bad dump, because the lines you've shown is not what
    you uploaded. When I saw the code had been extracted I put
    it down to possibly a different version of the MF2199 that
    I've not come across.
    From downloading your attachment I got this:-
    00x10 4E 73 D5 00 00 00 00 02 00
    Obviosly SITI has been very clever here, being able to
    manipulate this data in some way.
    And.. most probably limitations in my own knowledge in this.
    If experienced decoders can put me right on this, would be very
    grateful.
    Cheers.
    alexics's Avatar
    Jan 2010
    Kidderminster
    Quote Originally Posted by bonus2010 View Post
    grateful.
    Cheers.
    Siti has been clairvoyant as the data you posted from your download was wrong. zdzich posted the correct data above. I assume the radio had to be dumped again. The important thing is it was solved. That's why I appreciate the spirit of this forum.
    Jul 2010
    no, I didn't have to dump the radio, just put it back in the car and it worked fine.
  6. #5
    bonus2010's Avatar
    Mar 2010
    Scotland
    Quote Originally Posted by zdzich View Post
    We refer to a 'dump' as the memory contents of the
    security eeprom chip.
    I've very very recently discovered that the 'dump' can
    be provided in different formats. The dump that you
    originally posted was in a different format to what I
    would normally be able to recognise.
    Ok I know dump's got other meanings as well.....
  7. #6
    Jul 2010
    it was in bin format, the format that my eprom programmer uses. you would have to connect your eprom programmer and then open the file to read it.
  8. #7
    bonus2010's Avatar
    Mar 2010
    Scotland
    You don't need an eprom programmer to view a bin file.
    Every piece of data you can think of that is recognisable
    by computers is and only is in binary format.
    However, every application has it's own methods of storing
    data. These ways of storing data, all in binary format can
    include additional information, which is only recognisable
    by that specific application software.
    For example, I've just recently learnt that Polyprog stores
    data in a particular way - probably including data that is
    only recognisable by that application - and should that data
    be uploaded by an independant raw binary data analyser - would
    just appear nonsence.
    All eeprom applications have an option to store data
    in raw binary format, that's excludes any additional
    proprietry information being attached to the file.
    Thanks for your post, been doing a bit of learning through this...
    Cheers.
  9. #8
    Jul 2010
    I agree, but when you have a programmer connected to the eeprom in the radio it is very convenient to view the dump at that time. thanks for your comments.
