Results 1 to 2 of 2
    DK Veteran viejomatius's Avatar
    Jun 2009
    Default HELP WITH THE UPA USB PROGRAMMER!!
    i have bought a UPA USB PROGRAMMER WITH FULL ADAPTERS, i need help for make the connections for the "chip or mcu" motorola 68HC05H12
    what do i should do in the pin #9 there is a incomplete line(if you don't understand look the atached file)??
    do i have to disconnect the cable of that pin?
    or i have to unsolder that pin of the dashboard??
    i readed in another thread, And they say "you should lift the cable" but i speak spanish!! and i don't understand the meaning of "LIFT"
    can you help me?
    principaly my ask is the next:
    * do i have to energize all the dashboard; or when i make the conecctions this energizates with the UPA?
    *what do i should do when there is a incomplete line(look atached)??
    very much thanks!!
    eprommazza's Avatar
    Quote Originally Posted by viejomatius View Post
    can you help me?
    very much thanks!!
    12v dashboard with food if you do not need to connect 5v p9
    Sometimes there is' need to lift pin noise problems
    often rises reset tx rx bdm do not think the 5v
