Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    Default Audi CHORUS read code.
    Need help finding the radio code for Audi Chorus 8E0 035 152 Grundig.
    AUZ2Z2B2609705 020151003302609705.
    I read eeprom 24c16. Thanks for any tips.
    pawliukazz's Avatar
    Jupiter
    Quote Originally Posted by pomocrtv View Post
    Try 0459.
    I also added dump with resetted counter just in case
  3. The Following User Says Thank You to pawliukazz For This Useful Post:
    ktome (19th October, 2021)
    Thank you very much for helping set off the radio.
    Dec 2010
    hola, Alguien me podria Decir El Codigo de coro de radio la, Compre El Coche de Segunda Mano, y No Tengo El Codigo.
    fabicada en Portugal
    AUZ2Z2B2089712
    8E0 035 152
    ISTANBUL
    Exclamation
    Quote Originally Posted by goler View Post
    AUZ2Z2B2089712
    8E0 035 152
    not serial code in mcu or eeprom read send forum
    Dec 2010
    [Quote = ~~~ukum; 872844]no c?digo de serie en el MCU o leer eeprom enviar foro [/ quote]
    como se lee el eeprom?
    gracias
    ISTANBUL
    gracias
    EEPROM stands for Electrically Erasable Programmable Read Only Memory, and is pronounced double-ee-prom or e-e-prom. It's a long name for a small chip that holds bits of data code that can be rewritten and erased by an electrical charge, one byte at a time. EEPROM data cannot be selectively rewritten; the entire chip must be erased and rewritten to update its contents.
    While Random Access Memory (RAM) loses its data every time you power down your computer, EEPROM does not require a power source to maintain its data. For this reason EEPROM is commonly used by many BIOS chips to save system settings
    Dec 2010
    Thank you very much for his collaboration,
    Pardon for my Englishman
  10. #9
    ISTANBUL
    Exclamation
    no no Englishman I am from Turkey t?rkmen (osmanli )
  11. #10
    Zapp's Avatar
    Sep 2010
    Liverpool
    Default AUZ2Z2A1437040..GRUNDIG..24C16..code1753
    Can anyone confirm code please?
  12. The Following User Says Thank You to Zapp For This Useful Post:
    kappa1 (22nd June, 2015)
  13. #11
    Austria
    Quote Originally Posted by Zapp View Post
    Correct, 1753
    have fun.
  14. #12
    Zapp's Avatar
    Sep 2010
    Liverpool
    Quote Originally Posted by oep View Post
    Correct, 1753
    have fun.
    Cheers, Big Ears!!!!
  15. #13
    Lithuania
    Audi Chorus 8L0 eprom 24C16,
    need pin from this dump:
  16. #14
    zvasile's Avatar
    Quote Originally Posted by Min2xx View Post
    code 1501.....
  17. The Following User Says Thank You to zvasile For This Useful Post:
    kappa1 (19th December, 2014)
  18. #15
    Lithuania
    Quote Originally Posted by zvasile View Post
    code 1501.....
    Work fine, in what address is PIN? I can't find it
