Results 1 to 12 of 12
    DK Veteran kasim_izmir's Avatar
    turkey / izmir
    Default peugeot 307 7.4.4
    Hi to everyone
    Please can you help me , I want to read and write flash (29f400bb) its possible ?
    I try to read flash with galetto 1260 , I can read ecu info only
    please see picture in attach
    WBR
    turkey / izmir
    Quote Originally Posted by kasim_izmir View Post
    Hi to everyone
    WBR
    here is connection picture
    Netherlands
    give me all info on the ecu, maybe i can help you.
    turkey / izmir
    Quote Originally Posted by chiptuningnoord View Post
    ecu info = bosch number 0261 206 943
    ME7.7.4 96474 805 80
    BENZIN
    Do you need more details ?
    BR
    kasim
    BENZIN
    BR
    kasim
    Many seed-keys of cloned galleto not work correctly.
    Use way that above told you.
    turkey / izmir
    Quote Originally Posted by nicamarcos View Post
    Hi friends
    my friends , amen
    I give up to read band write via obd
    Thanks...kasim
    BATLER
    Guest
    Default ME7.4.5 replace
    hello,i d like to ask a question about ME745.I HAVE TO READ AND WRITE IT.i have only galletto clone and kwp2000 flashers and i dont know if my tools can read-write<probably not>!can i use ME7.4.4 in this car?is it the same?i can work with this one cause it is using 29f400bb flash and i program with programmer.thank you all.
    Beachside
    hello me 7.4.5 doens`t have a 29f400 it got a st1095 micro, also me7.4.4 could be done by obd2 in the bench becasuse the immo.
    BATLER
    Guest
    thanks for replay.so is it possible to replace ME7.4.5 with ME7.4.4?
    Beachside
    yes but you could loose some functions like cruise control if you got some patience (i don`t remeber well) you could try to read on the car with galletto, also you could use the information that gives you a pin to make connections form obd2. sorry i don`t remember well because i use cmd now but i could remeber i was able to read an d write by obd2
    BATLER
    Guest
    cmd!clone or original?
    Hi to everyone
    WBR
    Tip:
    Try to read ECU on the car. Car must have working immobilizer. After immo code is received form ECU, you may not have problem with seeding!
    Or
    This is hard to do, get ECU , BSI , immo-coil and key on bench....
