Results 1 to 8 of 8
    Jul 2010
    Default Stupid problem while (not) following tutorial
    Hi there!
    I've got a bit of a problem, I followed the "Wii 4.2E softmod tutorial. Easy to follow guide." and I got a blackout in my brain or something and pressed A in all the prompts in part 7 of the tutorial, after that I panicked for a while then I read this "If you accidentally delete any other stub IOS, it is not the end of the world. However when inserting an original game disc it may ask you to update your system. Should this happen to you visit the ?safe upgrade to 4.2 page?, and follow the instructions in that guide to recover your IOS files to the latest versions." butI can't find that page anywhere?
    Please help me fix this, or just point me to a guide somewhere, all help is appreciated!
    // David
    V.I.P. Member ck-ok's Avatar
    Dec 2008
    nottingham
    Quote Originally Posted by bigbadbeg View Post
    Hi there!
    // David
    try here Digital Kaos - Downloads - v4.2 safe firmware updater
    Jul 2010
    Thanks!
    That worked just fine!
    Jul 2010
    just done same mistake will try now
    hi can anyone help my wii was soft moded to 4.2e my kids accepted update now its on 4.3e and everything stopped working ie negamma home brew gone. can it be down graded thanks.
    Aug 2010
    many thanks
    Nov 2010
    Hopefully I will be giving this a try shortly, also made the same mistake!!
    Nov 2010
    gonna try it done same
