Results 1 to 3 of 3
    Mosc
    Default Fiat Stilo 2004 Power Steering Problem.
    Hello, I have a problem with Fiat Stilo 2004r. 1.4 16v. Not working Power Steering. I checked the fuses, charging voltage,.
    In measuring block's sometimes not display position- steering wheel sensor, but when the display position 0 - 520 deg 0 - (-519 deg) - errors all the time, and Power Steering was not worked.
    I saw a solution to this problem in a Fiat Punto but I think there other Power Steering Column???
    FiatEcuScan display 2 faults:
    - C1007 Faulty actuator
    - C1013 Faulty ECU
    After removal of the errors come back, or both simultaneously or separately, each of them.
    If anyone has met with such a problem?
    Power steering is TRW.
    Thank's
    Top Poster + autoelectric's Avatar
    Greece
    I had the same problem with a Fiat Stilo about one year ago.
    The problem was on the motor. Although i didnt manage to fix it because is a lot different than Punto.
    I had to change it with a used one.
    Aug 2010
    Yes, the punto steering it'not the same,!!!!
