Results 1 to 6 of 6
    Jul 2010
    Melbourne
    Default T300 PROGRAMMER! 100 TOKENS REMAINING.
    Hi All.
    Recently Bought A T300 key tool. When I Plugged It On It Says 100 Tokens Remaining. WHATS THE BIG DEAL? does it mean i could only use it to program upto 100 keys coz if it is that sucks. Thanks For The Reply.
    Jan 2010
    What? You mean you purchased a tool without looking into it?? If it is indeed a pucka unit then yes you have 100 goes left,after that a purchase of tokens will be required. You then charge your customer with this cost in mind.
    racin-snake's Avatar
    Jun 2009
    nope this will always show 100 tokens whenever powered up its a t300 a clone of the ad
    the token issue was cracked a long time ago
    use as many tokens as you like it will not deplete
    as soon as its powred up again 100 tokens will still remain
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Jul 2010
    Melbourne
    I Have Not Been Able To Use This T300 Tool . I Need a More In depth Explanation On How To? I Bought This Machine Hoping I Would Be Able To Duplicate Keys And Transponders For My Customers, Still Trying To Kick Off This Business But I Need More Training On The Key Programming "Sector". Cant Understand The Pats Sytem And What Not.
    Jun 2009
    t3oo will not clone a key it just programs keys or matches them to the car via the pin
    its not a transponder cloner its a key programer
    its pretty much self explanatory if you have some knowlege
    it will let you sync key with uch ecu ect but will not clone anything ????
    Jun 2010
    France
    Smile t300
    if you have to do a volkswagen passat 2005 key( chip crypto 48 ) you need t300 to read pin and program new key but you must have at last one working key if you don?t have any key you need to get pin number from de VW dealler or read ecu with others interfaces in this case if you use a clone device the key not work.
    If you have a opel corsa b clone device is good to make a spare key.
