I would check injector duty cycle with the standard software first. That may be close to the limit all ready.
Hi, i'm new to this site. Wonder if somebody can help me please
I'm after a tunned file to reflash my ECU for:
2001 A3 180BHP - Quattro _ KO3s
ECU Number: 06A 906 032 BJ - Bosch Number 0261206892
other numbers stamped on ECU:
26SA7193
1159 0057
00-10-18
ME7.5 0001
BPG Motronic
I have come across the ebay ones..... But I don't even want to give them a try. Just in case.
Has anyone got a good one that has been tested?
I was going to use MPPS for the reading/flashing and my VAG cable.
Ok thanks, i'll use vag com to check. I'll post my results, I can aslo upgrade the injectors to S3 ones if I need to.
I belive the stock injectors are 317cc so they should be fine, But still if I can get a log done tonight I'll post it.
Thank you for the reply,
all A3 180hp engine codes (auq, ary, app & ajq) can do 215hp 325Nm without stress. if you want to go higher you are looking at bigger injectors and turbo.
Sounds good to me I havn't had the chance to check what the duty cycle is, but i have been told by a few people now thats its fine.
If I go above that then I will need new injectors, turbo and larger MAF.
Engine Code is 'ARY' Same as the TT
@bigdave83
have you try already update ?
I?m looking files for my A3 3,2 Quattro_250hp (2005)
Hello I can help, but I need original file or SW version for both
Yes, but I can not download files because I have not yet sufficient privileges.
They could be built here, but also would have to send me. And like I said, I would suffice with the SW for the modified file. Would have no problem to upload it here if they do not care
how i can read the files, i have enough equipment for it.
