Results 1 to 5 of 5
    Member nikinik's Avatar
    Jul 2010
    Haskovo,Bulgaria
    Default xsara picaso sagem S2000 immo off
    hi mates! i need help for immo off on citroen xsara picasso 6FZ
    s 2000 sagem.inside is 95080 memory .make immo off with immokiller and car start 3 times then no starting.
    what can be cut?
    here i attach dumps.
    p.s. ecu is from another car and original ecu dump is fuc...up.
    i tried on 307 peugeot it works without cut wires,but here not
    H E L P
    Newbie sergiofior's Avatar
    Apr 2010
    Argentina
    Cut F3 and F4 half pin out
  3. The Following User Says Thank You to sergiofior For This Useful Post:
    wflseba (3rd August, 2017)
    Jul 2010
    Haskovo,Bulgaria
    thanks sergiofior,it works !
    for people that need help with this ecu,here explanation.
    find location of eprom (pic in immokiller)
    read eprom 95080
    clean with immokiller
    write eprom
    !!!cut line F3 and F4 on midlle connector of ecu
    thats it
    i will use thanks button mate!!!!
  5. The Following 3 Users Say Thank You to nikinik For This Useful Post:
    AleXPaiN (30th June, 2016), antwnhszr (11th September, 2017), wflseba (3rd August, 2017)
  6. #4
    Sep 2009
    Default xsara picasso s2000 immo off
    I have the same problem on picasso s2000-1 ecu
    same motor.
    I have done the same step 95080 with immokiller
    cut the two wires but when i connect ecu to car dont start
    I have desolder the chip for check if she is reprogrammed and she is.
    Does anybody has the pinout of this ecu?
    Thks fo your help
  7. #5
    Newbie tato's Avatar
    Jul 2010
    hello
    send pin out
    Hope this helps
    Greetings
