Results 1 to 8 of 8
    Default skoda symphony 24c16 code needed
    hi , i have a skoda symphony , technisat , 6Y0035156A with a 24c16 eprom . serial no. is SKZAZ8B1302655 . file attached . can anyone help with code please ??
    regards
    sparkle
    code 1954............
    thank you ank , but i think my dump might be corrupted , when i enter code it returns to " 1 SAFE " everytime . im using " >> " buton to enter , is this correct ??
    mabe somebody might have a working dump for this model ?
    regards
    sparkle
    anyone got a dump please ???
    sparkle
    alexics's Avatar
    Kidderminster
    Quote Originally Posted by sparkle View Post
    sparkle
    The code supplied is correct. The fact that it never gets off SAFE 1 indicates that it doesn't think you have entered a code. It would normally go to SAFE 2, SAFE 3 etc. I doubt if this is the dump. More likely a fault with the radio.
    bonus2010's Avatar
    Scotland
    regards
    sparkle
    In that situation, I'd want to test that you have both an
    ignition feed and permanent feed. I've noticed with many
    radios that if both lives are not present, it will not accept
    a code, particularly with Vauxhall radios.
    unit is definately powered up correctly , i have repaired these units before so im familiar with them . i think i need to dump to rule out corruption . anyone ??
    thanks for all replies guys
    sparkle
    ok guys . i got this sorted at last . when looking at the dump i realised the code was very obvious so i changed same to 1111 & rewrote that back into eprom . PERFECTO !!!
    entered code first time & it works 100% .
    many thanks to all who posted
    sparkle
