Results 1 to 7 of 7
    Jul 2010
    Default Eurovox EX6000 USB2 Revolution
    Hi All
    Have just got a new Eurovox EX6000. After following the instilation process I have found I can't get alot of Channels. It is saying scrambeld channel
    I am on Virgin cable is there anything I need to do or download to sort the problem.
    Many Thanks
    Top Poster + tommos43's Avatar
    Nov 2008
    Swansea
    If your in a Nagra3 area that box isn't going to work?
    dasteph's Avatar
    Nov 2008
    north east
    all you will be left with are channels 1-5 and there is no fix to overcome n3 encryption.
    Jul 2010
    Lancashire
    Default Nagra 3
    Is there any boxes you can use in Nagra 3 area instead?
    dasteph's Avatar
    Nov 2008
    north east
    Quote Originally Posted by 19kerrie53 View Post
    there are no cable boxes that are immune to n3 encryption unless you are prepared to cs for more info on that subject you will have to search for it as discussions about it are band on this forum.
    Jul 2010
    Thanks to all for your help. How do I know if I am in a Nagra 3 area.
    Top Poster Satguy Keano's Avatar
    Nov 2009
    NW UK
    Well if you are not now then you will be in the next couple of weeks.
    If you are ex TW region then you may have a few weeks left, it looks like VM are doing ex TW areas last, Liverpool,Wigan,Bristol etc.
    If you give us a hint where you are then someone will confirm.
