help me pizzz
help me pizzz
Try.
Must work.If not,then i need ori too.
With tool you read?
Br
I READ THITH MPPS.
IS THE ORI
can i write the file??
the cecksum is ok??
can i write this??
anyone can help me?????
Hi !
You can write my file above.
Best regards
thenk you.
this is my new files...
is 2 mod file.pleas correck the cecksum.
thank you very very muc.
plizzzzzzzzz
this map is ok.
i try this.
i try th end file in the upload rar file.
The car is one animale......
i try anather maps ,now i change only the rubo maps because
this start in the 1300rmp i like to start in 1500rmp.
the ecm driver for this maps is very very wrong.
if you know the maps for siemes ecu you take one biutyful job in this car.
thank you Daviee to help me for checksum corrector.
ecm dont correg checksum ....
thank you.
HUmm yes ecm dont make that , i only work with winols, some friend says the ecm make that...but it was wrong, ecm only calculate the checsum of all the file, but not correct it to the checsum nedded, like Winhex , i think its like this way....Original Exemple_3+1+5+1= 10 and Mod _like 3+2+6+8=15 and we need the same chs like orig 3+2+6+8=10
to calcolate the ck is the long work for me.
now i wait to bay the bdm,ck correct in write.
for the maps.you dont tell me haw turbo maps and limit turbo is??
i mod one and one but the car cut in 4000rmp.
i dont now wat is the problem.
i mod the turbo map and lim turbo,lim torque 5 of this,diesel map,accelerator pedal map.smoke map.
i dont now wats the proble....
i try many alternative...
best reguards
