can anyone help me,ive got a problem communicating with the ecu,im using cmd 1255.there is a tab on the right (obd).i have selected the car(vw golf 2005 2.0 tdi 140bhp).i understand this is a edc16 can....so ive bought the bdm....when i press the identify button,i get a error message-unplug cable or no power supply....i get this message with the ribbon cable pluged in or not......is the cmd software im using for a obd cable,or can this be used with the bdm100 ribbon....is there any other software i can use to try and make the bdm communicate ......any information would be grately appreciated
yes i no what you are saying...but....when i installed the software that is all i could use...i could not choose bdm or obd....
do you have the adapter 12 volts
thanks for the replys,and ive had a search,found a good thread on flasging the bdm.but the upload link was dead.and couldnt find another link with good instructions....and as for the 12volts....the bdm has a 12v power supply adaptor....but there is no 12volt adaptor for the ecu,if thats what you mean....
ive attached a picture of what i have...
You might have burned the BDM port of your ECU.
Check the GND pad of the ECU to see if it matches the ones of your BDM. Use a multimeter.
ecu is dead..
If clone you have the red stripe to the wrong side of pin one, the stripe should be on opposite side.
