Results 1 to 7 of 7
Hybrid View
    dreadfand
    Guest
    Default I've read and read and still no joy
    DK Veteran dank76's Avatar
    Nov 2008
    can be c instead of a and e
    Nov 2008
    read the stickies,i rang my mum talked her through it and even she got it to work...
    dreadfand
    Guest
    Nov 2008
    where do you live?,who is your provider?v m,t w?.you might be putting in the wrong codes for your area.
    Nov 2008
    Default try
    hi have you tryed to reset to default 1,menu 2,then ok 3,then tap in 1968 twice you should see your default key at the bottom of screen mine is yellow i think yours should be to 4, now put in the latest number from the keymaster hopefully this will work for you as it did for me
    dreadfand
    Guest
