Results 1 to 5 of 5
    DK Veteran sattv1244's Avatar
    Default CAT ET2009C kg have timebomb?
    In early July can alsoI use the 2009c KG for ET2010B but now! it dont works why?
    Top Poster TheCatDoctor's Avatar
    Quote Originally Posted by sattv1244 View Post
    just install et 2010a.license it using your KG then upgrade to et 2010b.U'll get the same license.
    DK Veteran RSwire's Avatar
    your girlfriends house
    Was it ET 2010B? I thought the KG only worked for 2009/2010A. 2010B needs new KG. Some one correct me if I'm wrong.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
    Quote Originally Posted by RSwire View Post
    I hadn't tried the keyget with 2010B ... I'll give it a whirl later this week and see what happens.
    Default 2010b
    can not use keygen directly on 2010b have to install 2010a use keygen to get up and running then upgrade to 2010b but it is a wast of time because 2010b has issues with trainer mode in the new winflash changes, also up coming versions will most likely have more changes to licensing
