Results 1 to 15 of 20
    Jul 2008
    Default Connection problems with Flash fxp and Filezilla
    I need help, whenever i try to connect the dbox to router either direct or through pc using crossover cables i get ''connection timed out'' error i have tried switching off my firewall but still to no avail can someone help me
    Oct 2008
    i take it you have the ip address set up correctly on both your network card in the pc and the dreambox
    you'd need something like 192.168.0.5 on your network card and 192.168.0.6 on your dreambox you should then be connection to 192.168.0.6 as the address name in flashfxp.
    also what username and password are u using?
    Sep 2008
    Quote Originally Posted by KingJojo View Post
    as stated by the above poster, you problem is related to your IP address I guess you PC and DM are on different subnets
    Jul 2008
    my dbox ip is 192.168.1.71 username - root password - dreambox
    my comps is 192.168.1.69
    Oct 2008
    ok that looks okay to me, and your entering the 192.168.1.71 into flash fxp?
    stupid Qs but you do have your dreambox connected to the mains and powered on, and your also 100% its a crossover cable you have rather than a patch cable
    Jul 2008
    dbox is powered on but on standby hmm let me try using a differant cable although iam sure its a crossover
    Jul 2008
    definately not the cables......
    my pc is connected to router
    dbox is connnected to pc
    dbox ip: 192.168.1.64
    username: root
    PASS : dreambox
    i missed the footy action today aswell.......
    Jul 2008
    Error: Connection timed out
    Error: Could not connect to server
    Oct 2008
    ok, so i take it you have 2 network cables on your pc then?
    oh and the football wasnt that great tbh mate, decent comeback from the arse but that was about it, spanish games tonight have been better
    Sep 2008
    can you do a ping from comp to db
    also a tracert would help as well
    also a routing table on your comp (route print in command line)
    def a routing issue here
    Nov 2008
    Your router is it auto senescing if so it will automatically self correct from a cross over to a straight so you may need to Look at that also a good pint that was made to make sure that you have the same sub net
    It should be class C ie 255.255.255.0 I hope that is of some help
    Jul 2008
    Default Connection problems with Flash Fxp and Filezilla
    Silly me when i connected to the internet via dbox it was showing the correct Ip Address when the dbox is dis-connected it showed a differant one.
    Issue Resolved thanks to all who helped me through this, thanks to Devilfish and the rest of the crew for a top site keep up the good work,
    To Stop this from happening in the future:
    Install Flash Fxp from this site or FileZilla Client (they are both free software)
    Once Installed connect your (pc to router via crossover cable) and (Dbox to router via crossover cable) yes this means you need 2 crossover cables
    Flash Fxp
    Server/URL: (Your Dbox IP)
    Username: root
    Passwrod: dreambox
    Port: (leave blank)
    FileZilla
    Open Site Manager and create a new site
    Site name make ? ?Dreambox?
    Host name is the IP address of the box ?192.168.x.xxx?
    Port leave blank
    Server type ? FTP
    Logontype - Account
    UserID is ?root?
    Password is ?dreambox?
    Account name ?dreambox?
    after this hit connect you should now be connected
    it is imperative that you make sure all cables are connected securely and that your cables are legit crossover not patch and if you still have problems your typing the wrong Dbox IP
    Once again thanks and enjoy
  13. #13
    Jul 2008
    whoops sorry after your connected follow Mubz guide and enjoy
  14. #14
    Nov 2008
    if i use a wireless router to get connected to the internet via my laptop, do i still need to connect the laptop to the router via an ethernet cable aswell as connecting the dbox to the router?
  15. #15
    Jul 2008
    You can connect your laptop to router via wireless but the Dbox must be connected vis crossover cable,
    If you experience any difficulties then connected the laptop to router one cable and Dbox to router another cable (in all you will need 2 crossover cables)
