I only have op-com, I think I'll give you advice, end code fo radio 28c64 ??? thank you very much
hi people
can somewone unregister and pin code to this radio CD30 MP3 from opel corsa d 2009 ?
best regards
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
Can anyone help?I bought a Corsa radio and display kit. But it turned out that they did not come from one car and were not logged out.Please log out the radio from the display and unlock the radio.If possible, please set the code 6908 in my car.Sorry for the English Thank you in advance.
Radio: Delphi Grundig CD30 MP3
Display: Delphi Grundig GID S4400 AS
damian0708 (24th November, 2019)
Thank you very much for help. Everything has logged in.
After a long standstill, the display flashes display safe, the Can configuration is done correctly. In errors there is B1000-36 replace electronic control unit (ECU). Should I change the coding in any module yet?
Zann (25th November, 2019)
I need unregister radio Blaupunkt CD30. NO: 13 190 853. GM003162884407. It is from Opel Vectra C. In attached dump from 95640 eeprom.
Hy..try and report ..
Hi. I want to install new (old) cd30 radio from other car to my car. I need unregister radio CD30 Blaupunkt (because I bought it as not unregistered). No - 13 190 856 YY. In attached dump from reding 95640 eeprom.
I read pin to car from the ecu with Carprog. The PIN read by carprog is: 0321. Is this pin code same for Display? How should I procced after I get unregister file?
I have got opcom too. Should I first code in EHU or in DIS?
or should I read Display eeprom too?
greetings
thanks for file. I will sent Display dump tommorow
here in attached dump from reading display (on display I have eeprom 93c66). In attached two dumps. First read as 93c66 8bit and second read as 93c66. Need PIN and virgin. And please to advice how to procced next with it for pairing. Do I need virgin dump only to radio or do I need to write virgin dumps to radio and display too?
GID - 13178765 siemens
greetings
