Page 82 of 130 FirstFirst ... 3272777879808182838485868792 ... LastLast
Results 1,216 to 1,230 of 1943
  1. #1216
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by Rafikvw View Post
    Can you please virginise it to me? Thanks!
    Use Tech2 and pair using 0237
    wbr
    Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
  2. The Following 3 Users Say Thank You to shooting For This Useful Post:
    mcd76 (21st November, 2019), Rafikvw (21st November, 2019), REZON (21st November, 2019)
  3. #1217
    Dec 2011
    I only have op-com, I think I'll give you advice, end code fo radio 28c64 ??? thank you very much
  4. #1218
    Nov 2009
    hi people
    can somewone unregister and pin code to this radio CD30 MP3 from opel corsa d 2009 ?
    best regards
  5. #1219
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by pkatra View Post
    hi people
    best regards
    Here you go, set to Virgin, for pairing PIN post Display dump 93C56 (8bit)
    wbr
  6. The Following 2 Users Say Thank You to shooting For This Useful Post:
    golo (23rd November, 2019), pkatra (23rd November, 2019)
  7. #1220
    Nov 2019
    Can anyone help?I bought a Corsa radio and display kit. But it turned out that they did not come from one car and were not logged out.Please log out the radio from the display and unlock the radio.If possible, please set the code 6908 in my car.Sorry for the English Thank you in advance.
    Radio: Delphi Grundig CD30 MP3
    Display: Delphi Grundig GID S4400 AS
  8. #1221
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by damian0708 View Post
    Here is Display & Radio unregistered, pair display then pair radio using 6908
    wbr
  9. The Following User Says Thank You to shooting For This Useful Post:
    damian0708 (24th November, 2019)
  10. #1222
    Nov 2019
    Thank you very much for help. Everything has logged in.
    After a long standstill, the display flashes display safe, the Can configuration is done correctly. In errors there is B1000-36 replace electronic control unit (ECU). Should I change the coding in any module yet?
  11. #1223
    shooting's Avatar
    Feb 2010
    WALES
    You need to register Display first then add radio
    wbr
  12. The Following User Says Thank You to shooting For This Useful Post:
    Zann (25th November, 2019)
  13. #1224
    May 2017
    Poland
    I need unregister radio Blaupunkt CD30. NO: 13 190 853. GM003162884407. It is from Opel Vectra C. In attached dump from 95640 eeprom.
  14. #1225
    tazz75's Avatar
    Nov 2018
    Hy..try and report ..
  15. #1226
    shooting's Avatar
    Feb 2010
    WALES
    Quote Originally Posted by kobi2311 View Post
    Here is the Correct Virgin dump,
    (Don't use above as is not even from the original radio)
    wbr
  16. #1227
    May 2017
    Poland
    Hi. I want to install new (old) cd30 radio from other car to my car. I need unregister radio CD30 Blaupunkt (because I bought it as not unregistered). No - 13 190 856 YY. In attached dump from reding 95640 eeprom.
    I read pin to car from the ecu with Carprog. The PIN read by carprog is: 0321. Is this pin code same for Display? How should I procced after I get unregister file?
    I have got opcom too. Should I first code in EHU or in DIS?
    or should I read Display eeprom too?
    greetings
  17. #1228
    shooting's Avatar
    Feb 2010
    WALES
    greetings
    ECU pin may not be the same, post Display dump 93C56 8bit for pairing PIN
    Here is your radio Virginised
    wbr
  18. #1229
    May 2017
    Poland
    thanks for file. I will sent Display dump tommorow
  19. #1230
    May 2017
    Poland
    here in attached dump from reading display (on display I have eeprom 93c66). In attached two dumps. First read as 93c66 8bit and second read as 93c66. Need PIN and virgin. And please to advice how to procced next with it for pairing. Do I need virgin dump only to radio or do I need to write virgin dumps to radio and display too?
    GID - 13178765 siemens
    greetings
