up !
i use clone upa and clone xprog-m, both work brilliantly. UPA is better for 8 leg eeproms, as it reads and verifys without problem first time every time, on eeproms i find xprog-m moaning about "bad contacts" all the time.
But for mcu,s i find myself going for the xprog-m , because if mcu has security most of time xprog-m can by-pass it.
You need every tool in the book, to do this auto locksmith job.
omega orange
good: works great with loads of eeps and micros
doesn't byte swap unless you tell it (or do it wrong)
zedbull's tool of choice
loads and loads of adaptors and icsp stuff including EWS
bad: 29fX00 isnt supported
For Immobiliser the all round favourit would be the Omega MTRK & Orange.
They offer various packages, build your own to suit yourself.
Scorpio-LK
You'll find however with all things, one reader is never enough!!
Seeprog is also excellent for EEprom
I have andromeda research. It will read a 93 chips in circuit. I also used it on several hc05 . They have good support too.
PonyProg is easy and works great also
A cheap programmer i use , not to let me down yet is,is GQ-4x.
regards
home made ... cheapest ...
br
I have a true usb based on the pickit 2 but with dil sockets also on board,easy install etc and only cpl of jumpers on board,so kept simple.
Waiting to remove 93a66 eeprom from before i comment on how good ir works as i will sub this eeprom with 93c66 if its ok to do that.
Tried a "clip" but no luck,so need to remove eeprom and ordered a soic/sop 8 to dil adapter 150 mil for reading/writing on dil socket on board.
My car ( toyota iq ) is not listed in tachopro calc etc,so if i manage to read orig dump and post here will someone know what to change to correct the odometer?
thx in advance
