Page 3 of 9 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 122
  1. #31
    Sep 2010
    Sry to ask this here...do any of you are expert in vas5054A ?
  2. #32
    Top Poster + Iroll's Avatar
    Default Hi,
    Are you using the latest Firmware Update 5.5.0 for dice?
    Don?t forget the ?Thanks Button?
  3. The Following User Says Thank You to Iroll For This Useful Post:
    techman1 (18th May, 2021)
  4. #33
    impactops's Avatar
    Quote Originally Posted by Iroll View Post
    Do you have Hi-RES pictures of inside the interface you could post
    Impactops
  5. #34
    SadCriss's Avatar
    At the Garage
    I hawe a problem whit Dice too.I can not establish comunication whit car and when make interface test give an error can anyone help me please???
    I atach some picture
    If It helps you try push the: Thanks and REP
    I do the same each time it helps.
  6. #35
    Default Hi,
    When you are connected to the car, select the right Partner Group before reading vehicle.
    Please! don?t forget the ?Thanks Button?
  7. #36
    SadCriss's Avatar
    At the Garage
    Please! don’t forget the “Thanks Button”
    I hawe done that but when give to read car the interface restart and I hear the usb disconect and conect back sound and led on interface show like it disconect and reconect.
    I not understand what hapens or maibe problem on car? I test on xc90
    Thank you
  8. #37
    External flash test doesn't look right.
    Last edited by somad; 12th November, 2010 at 11:09 AM. Reason: Removed additional question.
  9. #38
    Romania
    this place is missing in the ignition and batery status
  10. #39
    Default Hi,
    I have noticed in 2010A sometimes it?s there and sometimes not. I think it?s related to different models? I will pay more attention to it.
  11. #40
    Default volvo vida
    buy dice from volvo the price is 800 euro i didd
  12. #41
    Top Poster + Kanaan's Avatar
    in my car
    I have the dice one year ago 1300 usd .
    it has sd card that can store last 10 vehicle diagnostics.
    I comunicate using blutooth or cable .
    the only problem is that it is very expensive to get online software downloading .
    so I need to use it without this function .
    God does not play dice with the universe . (Einstein)
    if anything can go wrong it will . (Morphy laws)
  13. #42
    Sep 2010
    Quote Originally Posted by SadCriss View Post
    Thank you
    I had 2 units with the same serial number as yours, both worked for few days and then did the exact same thing as yours, i was able to return one of them and get my money back (I lost $100 in shipping fee) and the second one, i sent once to seller (paid $100 shipping) to repair, but they sent it back with the same problem, so i sent it back again to them (another $100 shipping) for a replacement or refund, if they ever answer my emails again!!!!
    So conclusion is your tool is probably a paperweight now as mine were.... your best bet is to return it and get a refund.
  14. #43
    SadCriss's Avatar
    At the Garage
    The ignicion apear only when go to diagnosis menu...
    These is brand new from china...
    Once I hawe test a V70 and it vas all ok now try on XC90,S80 and not working always look like i remove interface from obd and put it back.
    The led from "USB com status"blink for a second and after that all led go out and back again like I remove and insert back obd conector to car.
    Can these problem come from laptop too?
    THANK YOU ALL!!!!!!!!!11
  15. #44
    SadCriss's Avatar
    At the Garage
    Quote Originally Posted by parezoo View Post
    Where did you buy yours?
  16. #45
    Nov 2010
    My buddy has a cloned DICE unit, it works ok, but occasionally he will have to try and read the VIN a few times before it works properly , low battery charge is aother issue he faces.
    There is also the fact that it is voltage sensitive, when trying to diagnose or read, ensure car battery is at optimum level, and try not to start the car too often, voltage spikes may cause the unit to fail. Instead use an outboard car battery charger at low/trickle charge, it should give the battery some juice ( 11.5V )
    hope this helps
