Results 1 to 4 of 4
    Default Ford Transit cruise control
    Is it possible to fit a cruise control steering wheel and enable the function in the ecu on a 09 2.2 tdci ford transit.
    Staffs UK
    the ECU is capable of cruise but I aint sure about the column/wheel connections.
    If ford offer it as an option then you will be able to retrofit it
    All the wiring seems to be there as well as clutch and brake switches ,what is the best interface to communicate with the ecu on a transit
    Staffs UK
    IDS only for retrofit or recoding
