Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Member Floyd's Avatar
    UK
    Quote Originally Posted by hipolitogt View Post
    I can use even ver 16, 17 and 18, I think the problem is you are not configuren the edic I will search for a tuto of configuring it and I will post here, but I never have a problem configuring it...
    I have just replied to another post regarding this.
    You find it in vaspc, admin, documents and then you find how to configure/install the interface.
    It can be a pain in the but, to be honest I just use mine via usb, it's Sooooo much easier than bluetooth.
  2. #17
    If the hardware is ok and no mixup in the COM ports I prefer Bluetooth, no hasle with cable and diagnostic run's even on the passenger side with no cable between your feet.
    But you are right, the more secure and stable method might be the cable one.
    Regards,
    Xaver
  3. #18
    chakahafed's Avatar
    nouakchott
    Quote Originally Posted by Xaver View Post
    With which software did your VAS come. I had the sme problem with a cheap VAS version without bluetooth. It came with version 15 but did never run even with newer versions as v16 or v17 not.
    If you have the screen after tappin Edic hardware installation you should go to Edic software configuration. It should show something like in the attached picture. If not, the device isn't recognized and assigned correctly.
    Regards,
    Xaver
    I DONT HAVE THAT SCREEN !
    this is what i got when i add edic in edic HW Installation ! see PIC1
    when i connect via USB the interface is detected but i cant open the VAS PC , i see a progression screen like the pic 2
  4. #19
    @chakahafed
    Just go into your system device manger of windows and see to which COM port the Edic is assigned to.
    Than in Edic hardware installation add Edic with the correpondet COM port you found in the device manager.
    To correct problems with the COM port follow:
    My Coffee cup: How to clear or Reset COM port ?
    Xaver
  5. #20
    May 2009
    COM Name Arbiter Setter V0.1 - gives control over reserved COM port numbers
    Freeware by Uwe Sieber - Uwe Sieber's Homepage
    Whenever a new COM port is installed, Windows looks for the first
    never used number. This ensures that there are no conflicts when
    two of the devices are attached at the same time.
    In real live the users do not use their devices (as USB to COM adaptors)
    at the same time, but the COM number increase and increase...
  6. #21
    Yes that's it.
    The vas obviously can not handle too high COM ports.
    That's why sometime a com port reset does help.
    Xaver
  7. #22
    hi i have 4 in stock genuine vas 5054a heads from vw there are very hard to get hold of please pm me paul.bill@live.co.uk if you need any assistance i also have the latest software if anybody needs please let me know and i will upload great site by the way
