Results 1 to 4 of 4
    Aug 2010
    Default tm500 super channel editor
    Hi i guess the title says it all i'm looking for somting to setup my channels list into favorites in order like my dreambox which also saves my frequency setting for channels anything out there i can use thanks in advance ps tried the db edit no joy
    Jan 2009
    Hi mate
    Dbedit works a treat maybe you have not set the correct settings
    in tools. I set mine to 2. (im using a Tm600 )
    Its also a useful program to backup your
    services/bouquets sat.xml file for use again if required which you can upload again on a second box.
    Aug 2010
    Quote Originally Posted by mandata View Post
    Hi mate
    i'm already using it for dreambox but how to use in tm500 aint got a clue plus really could do with bounquets like dm does it all in 3 sec rather than 40 plus mins give the tools setting a go
    DK Veteran hooley's Avatar
    Galway Ireland
    If you have used dbedit for dreambox, its the same process for a TM500.
