OK, got myself into another trouble. Tryed to reflash the eeprom on the dash responded with the "Def", after trying reflashing with the propper dump it now says "Fuse". What does that mean? The incar fuse for the dashboard is ok.
You have corrup the dump..
Not work if you remove fuse.
Try other dump or put original dump..
I have tryed to write the right dump, but it doesn't work. I mean, K+can commander says everything is written but the the dash just doesn't accept the new dump.
you need to maually strip cluster and write dump manually
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
Ok, I've done that too, the dash is 4B0 920 933 N, the EEPROM is 93c86? Right? I've tryed to write it manually, but it didn't help either![]()
btw, what is the position of 93c86 on the board, I couldn't find pin 1 position.
Hi!
Did you solved this problem?
I have the same problem here.
Middle display not work only "FUSE" on the right siplay, buzzer on , voltage and temperature meter is on the max.
I already try all dumps in forum, but the same results. :-(
Maybe Micronas is damanged?
Thanks, but i checked. This one don't have power line on green connector (this is with 3 connector : green, blau, grey) only in the blue one have 2X+12V
So i think it's another problem :-(
