Page 7 of 10 FirstFirst ... 2345678910 LastLast
Results 91 to 105 of 148
  1. #91
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    From your start button go to accessories/communications/hyper terminal
  2. #92
    Oct 2008
    Thumbs up
    this was great help as my box died on me and could not use ftp. Thanks mate good work.
  3. #93
    Mar 2009
    Default brilliant.....thank you so much
    really good info......thanks
    Quote Originally Posted by aftermath View Post
    part 2.
    now type in dl 800000 . Then press enter
    you should see this : S Record Load, offset: 800000
    Download the attached u-boot.mot file
    Next click on Transfer on top of hyperterminal window, select "send text file", select type of file "All files",
    select the file u-boot.mot (attached here) and click on "open" to start the transfer.
    The file transfer take about 5 minutes and in hyperterminal no announcement appears about the process of the transfer.
    You will now need to type in the following command and hit enter.
    This will start the u-boot file we just transferred.
    As this is starting it will try get a network connection, as we do not want this, we need to break out of it. You do this by holding down the control key on your keyboard and pressing the ?C? key at the same time. This needs to be done before 3 attempts at the connection. You will be returned to the command prompt again. So type the following command.
    chorus 800000
    Keep control key pressed when its trying to connect to the network and press the ?C? key and you will be returned to the command prompt. NOTE: the command prompt has changed a little bit and now looks like =>
    This is normal :>)
    should see a screen something like this.
    Now type in :- loadb 120000 115200
    You will get the following message
    ## SWITCH Baud rate to 115200 bps and press ENTER
    in Hyperterminal stop the connection
    Call -> Disconnect),
    click File -> Properties ->
    change the Bits per second to 115200.
    Click on ok and leave the menus.
    Reconnect with Call -> Call on top of the hyperterminal window.
    Press enter on keyboard.
    you should now see this command : - ready for binary (kermit) download to 0x00120000 at 115200 bps
    NOW TO TRANSFER THE IMAGE.
    On top of hyperterminal window click on Transfer then send file,
    Choose your image (image without bootloader)
    Then choose the "kermit" protocol.
    Click on send.
    you will get a screen something like this.
    This will take about 45 minutes.
    Hyperterminal shows the transfer process inside a extra window.
    After transfer u-boot announces
    ## totally Size = 0x007E0000 = 8257536 bytes
    ## start ADDR = 0x00120000
    ## SWITCH Baud rate to 9600 bps and press ESC
    Click File -> Properties -> Configure and change the Bits per second to 9600. Click on ok and leave the menu.
    Press ESC on the pc keyboard
    u-boat prompt appears again "= >"
    Type in .
    protect off 10020000 107fffff
    Press enter then type in
    erase 10020000 107fffff
    cp.l 120000 10020000 1F8000
    Wait untill it says Done.
    The procedure take about 2 minutes.
  4. #94
    Default dead dbox2
    Worked a treat,was ready for binning box,Thank's,
    Great Stuff,Thank's Again,Nicky13.
  5. #95
    Nov 2008
    Default where can i get uboot mot file?
  6. #96
    Thumbs up
    Just want to say a big thank you to everyone for the info on this thread. Sorted......
  7. #97
    Apr 2009
    just out of curiosity..why is this method better compared to using a cross over cable?
  8. #98
    Apr 2009
    Quote Originally Posted by mo123456789 View Post
    Null Modem (RS232) method of flashing is supposed to be safer than using crossover (RJ45) methods, though faster.
  9. #99
    May 2009
    Default dave
    hi there im new to this site the question i hav is that i hav a pace cable box from virgin media the box was chipped and now it needs flashing would the setup u hav put down hear work 4 me to get the tv channels bak on and also wot do u mean by dbox2 i would b greatful if u could help me with this plz.
  10. #100
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    Quote Originally Posted by davelove View Post
    We do not support modding CC equipment it is against the rules.
    A Dbox is not VM equipment but an old box which can run Linux, which then can be programmed to recieve / decrypt channels.
    XBMC/KODI Developer
  11. #101
    plasterer's Avatar
    Jun 2008
    Mersyside
    Well aint that a bit Dodgy 2......................Paul.......LOl
    PAUL
  12. #102
    V.I.P.P.T. Member
    Sep 2008
    Just off the M1
    Quote Originally Posted by plasterer View Post
    Maybe just a little
    XBMC/KODI Developer
  13. #103
    Feb 2009
    iv tried connecting to COM1.. keep the button pressed in and switch on the box.. but nothing happens. the 5 bars appear on the lcd but there is no change on the hyperterminal screen. what am i doing wrong here please?iv connected using a USB to RS232 cable from my laptop.
  14. #104
    Thank you this was really helpfull i will try to flash my dbox2 now it doesnt seem that hard the way you have described. thanks
  15. #105
    Feb 2009
    ive done a few this way,long as you follow it word for word,dot to dot etc.its easy ,good luck mate
