Page 25 of 35 FirstFirst ... 152021222324252627282930 ... LastLast
Results 361 to 375 of 514
  1. #361
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by astra98gls View Post
    Hi everybody. I can't operate the tape of my car. Because I don't know code. Philips car 400 for opel astra hb gls 98. Please help me.
    GM 90 506 173
    Please����
    Quote Originally Posted by masterskay62 View Post
    Hi, please rooms embossed metal casing starting GM0400
    GM 90 383 441
    Pardon.
    GM0400W2152285
    GM0400W2152285
    Thanks a lot
    Try code .. 7375
  2. The Following 5 Users Say Thank You to Albert G For This Useful Post:
    Antony50 (19th July, 2020), Decode Ghost (20th July, 2020), jeank (19th July, 2020), masterskay62 (19th July, 2020), momogsm (20th July, 2020)
  3. #362
    Jul 2020
    🙏🙏🙏 thanks thanks thanks
  4. #363
    Jul 2020
    excuse me, but the code did not match. what can I do
  5. #364
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    Code From Serial Is : 7375, If It Not Work, First Check Your Serial Then Try In Car.
    If It Still Not Working, You Should Read Eeprom 24C16 To Get Your 100 Per 100 Code.
    Good Luck
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  6. The Following 2 Users Say Thank You to momogsm For This Useful Post:
    Decode Ghost (21st July, 2020), shooting (21st July, 2020)
  7. #365
    Jul 2020
    Hi everyone. I can not use radio in my car. Need code.
    Philips Car 400 2F3
    GM0400Y2961817
    Please, help
    Thanks a lot...
  8. #366
    Jul 2020
    Or can someone help me, how can i calculate it? I dont have any equipment, to read the eeprom, so the only solution is to calculate. Or if somebody have this information in the database.
    Philips Car 400 2F3
    GM0400Y2961817
    Please, help if you can!
  9. #367
    Decode Ghost's Avatar
    Aug 2015
    unfortunately, not in the database
  10. The Following User Says Thank You to Decode Ghost For This Useful Post:
    Opel Astra 17 t (28th July, 2020)
  11. #368
    Jul 2020
    Thank you very much in every case. Do you have any information about calculation?
  12. #369
    Jul 2020
    How this calculation works?
  13. #370
    Aug 2015
    don't worry about it my friend go to local decoder or authorized service and get the code for a certain fee
  14. The Following User Says Thank You to Decode Ghost For This Useful Post:
  15. #371
    Jul 2020
    Thanks a lot. I will do that.
  16. #372
    May 2018
    hello
    code needed
    no : 90532621
    gm0400v1555025
    90222319675201
    0039711555025
  17. #373
    Feb 2010
    WALES
    Quote Originally Posted by mothana View Post
    hello
    code needed
    no : 90532621
    gm0400v1555025
    90222319675201
    0039711555025
    Your code is 7221
    wbr
  18. The Following 2 Users Say Thank You to shooting For This Useful Post:
    ilen (2nd August, 2020), singlewolf (25th December, 2020)
  19. #374
    May 2018
    thank you man
    you are the best
  20. #375
    Nov 2020
    Hello please I lost my code of my Philips 400
    1 614 438
    Gm 90 506 173
    Thanks a lot for helps
