Page 2 of 10 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 148
  1. #16
    helmi reguig's Avatar
    May 2011
    altamura bari it
    Exclamation
    Quote Originally Posted by LuisAndre View Post
    Not true... you also need to change the security check sum.
    If you only change the version number, it will not work.
    Alpha
    IT MAKES A BROTHER WE THE RESULT OF UPDATED ST6000
    HOW TO MAKE HIS E PLEASE HELP VOU
    IL UN FRERE DONNE NOUS LES R?SULTAT DU MISE A JOUR ST6000
    E COMMENT A FAIS SA MERCI DE VOU AIDE
  2. #17
    BY
    Who can knows as to edit, 24c16?
  3. #18
    Milky Way
    Quote Originally Posted by evgenijm View Post
    I do. I can activate any tool to version 255 on cars and trucks and activate DPT .
  4. #19
    poland
    Does the activation of up to 255 all works?
    Can you do it yourself,
    do I need to send you a file?
    I have a CD111
  5. #20
    BY
    Please, help me.Many thank`s.
  6. #21
    Milky Way
    Quote Originally Posted by PKOWA View Post
    I have a CD111
    Yes. Yes, and yes.
  7. #22
    poland
    Yes. Yes, and yes.
    ok LuisAndre Tomorrow I will read 24C16
  8. #23
    poland
    read 24C16 CD111
    thank you for the conversion
  9. #24
    Milky Way
    read 24C16 CD111
    Here you go:
  10. #25
    poland
    Here you go:
    All the update to the CD128 acts
    Upgrading to CD135
    big thank you buddy
  11. #26
    Hi, LuisAndre, please can you do this file...
    Thanks !!!
  12. #27
    Quote Originally Posted by giuseppe1374 View Post
    hi, I removed the bee brain and I saw that there are two memory 24c16, which is what is planned? anyone has any photos?
    Best Regards
    The rear pcb, isn't need unmount the i2c, if you bridge the xtal the microcontroler isn't start and you can read the eeprom.
  13. #28
    Milky Way
    Quote Originally Posted by TeiS View Post
    For the ST6000 you need the 24c16 located at the back of the pcb. You have on your file, V123 activated for cars and comercial vehicles. Your file with V135 for everything:
  14. #29
    Jun 2009
    I read again back pcb 24c16 the st-6000 V125.52.
    please activate.
  15. #30
    Milky Way
    Quote Originally Posted by amaflo View Post
    I read 24c16 the st-6000 V125.52.
    please activate.
    You have read the wrong 24C16. On the ST6000, you have another module on the other side of the main board. To have access to this module, you need to remove the main board completly.
