Hi i posted yesterday about setting up my new box, i've tried all of the things others told me to try but still cant get any channels apart from fta. I started all over again i did
factory re-set
then plugged the usb stick in
turned the box on
menu/utility/ then selected usb
carling file with a cog at the side of it, is this right? or should it be like a yellow file?
highlighted it and pressed ok
selected s/w data it did'nt say sw+all data??
box re-booted
auto cable search for channels
scan finished so went to accessory pressed 8989
emulator appeared not k*yedit??
go to emulator k*yedit is there
press ok it says system 1 nagra
press ok on that it goes to a table with providers 0-7 on it
Must have fu**ed up some were any help!!!!!
