Results 1 to 5 of 5
Thread: power up
    tunisia
    Default power up
    Hi, just got the d500cs and seem to have a problem after switching between sat and cable. Only by switching the power off and on at the mains several times will the box power up. Box seems to be ok when running.
    V.I.P. Member westkill's Avatar
    May 2008
    your suposed to power down first to boot each image for each tuner
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
    DK Veteran psats's Avatar
    Sep 2008
    it sounds like the power board has caps that need changeing
    Nov 2008
    N*L EIRE
    Post
    Quote Originally Posted by hbstun View Post
    In layman's terms;
    To change from cable to sat or vice-versa you must power-off box first, switch cable/sat selector, then power-up box.
    It's a bit primitive, but that's the way it works.
    hmmm, strange
