Page 39 of 41 FirstFirst ... 293435363738394041 LastLast
Results 571 to 585 of 610
  1. #571
    Aug 2011
    uk
    Default re v22.14
    Hi can somebody give me link for v22.14 please, thanks
    Now got v22.14 thanks to the man
  2. #572
    Sep 2012
    Excellent work, thanks a lot!
  3. #573
    Member evobag's Avatar
    Sep 2011
    Default probleme lexia 3
    hello i have probleme
  4. #574
    Default Hello, I have this problem too ... can anyone help??
  5. #575
    Possibily more people can understand your problem if you switched the operating language to English and try to generate the problem again.
  6. #576
    changing the language in the language menu does not change, it still shows the original installation language, translated it is: wrong data from the portal, check the configuration. After reinstalling everything is the same. It can not be in the registry? thank you
  7. #577
    DK Veteran Larue's Avatar
    Somerset, UK
    Quote Originally Posted by hhp View Post
    Did you manually delete related folders from drive C and did clean up registry after uninstall?
    If NO then do that and you should be OK.
    Also. Was computer connected to the internet during registration process? If NO Then connect it when making registration.
  8. #578
    I need pin code peugeot 206 vin vf32akfwu43885188
  9. #579
    Apr 2012
    italy
    Smile go
    perfect
    Quote Originally Posted by scarymistake View Post
    Lexia update without internet (citroen)
    Fom V345 to V347.99
    https://rapidshare.com/files/3806577372/LuV34799.rar
    Only to update version345
    Most clone sets have the version 345.13
    This one you can update to version V347.99
    To instal Lexia by clicking on Instlex3
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    PP2000 update without internet (peugeot)
    From V22 to V24.99 (code to install downl the txt)
    https://rapidshare.com/files/3894084562/PuV2499.rar
    Only to update version 22.
    Most clone sets have the version 21.14 0.9A
    This one you can not update to versie V24.99.
    First install version 22 and then updating to version V24.99
    To install PP2000 you have a DVD or an iso program needed
    how to install lexia and pp2000
    YouTube - LEXIA AND PP2000
    YouTube - Install LEXIA PP2000 hd.mp4
    Lexia and PP2000 simulator
    by ZeroCool
  10. #580
    Jul 2012
    Hello Scary! Do I have the Chinese clone of the pp2000 versioned 21.14 and Lexia believe that the 45 (not sure) is there any possibility of help me reinstall the 22, then install the most recent? I would greatly appreciate your help!
  11. #581
    Jul 2012
    Default Help!
  12. #582
    Jul 2012
    DK Veteran m3vuv's Avatar
    woodhall-spa lincs
    any idea of the pw for the lexia rar file?,cheers Paul.
  14. #584
    Spain
    Quote Originally Posted by m3vuv View Post
    Try scary01
  15. #585
    woodhall-spa lincs
    thanks for your help but that didnt work.
