Page 19 of 41 FirstFirst ... 9141516171819202122232429 ... LastLast
Results 271 to 285 of 610
  1. #271
    Feb 2010
    Now I uninstall all and re-install LEXIA-345 only. And the problem all goes on. Again activation is OK, again PC identifier code is 0, again no connection with cars... any more idea please?..
  2. #272
    DK Veteran Larue's Avatar
    Jan 2010
    Somerset, UK
    Have You deleted APPLIC folder from disc C after uninstallation? If not - uninstall it again, delete this folder and then do installation from beginning!
    Cheers!
    ....by the way! Take search on DK. I think have seen something like that before here.....
  3. #273
    Feb 2010
    the problem should be about the module. I will inform you if I can pass the problem with another module.
  4. #274
    Jan 2011
    Download not available
    The following download is not available:
    http://rapidshare.com/files/41195287...6.68.exe.html0 KB
    please new link.Thanks
  5. #275
    scarymistake's Avatar
    Apr 2009
    Europe EN
    Quote Originally Posted by MontiT View Post
    Download the nw. update 347.28 first post
  6. #276
    maaxxyy's Avatar
    North Pole
    Hi guys this is my second go at updating my lexia and pp2000, i'm running lexia 345 and pp2000 21.14. I need to install pp2000 v 22 first but i dont have it. Does anyone have a link for v22? Thanks
  7. #277
    Jan 2011
    Hi !
    I have a Citroen Berlingo 1.6 HDI.
    Where can I buy an Clone Adapter to
    connect the car to the Notebook and
    use the Lexia 3 Software ?
    Thank you !
    Pom
  8. #278
    Jan 2010
    Use search. I have created one post about that. It works with virtual box.
  9. #279
    Jan 2010
    Quote Originally Posted by croatiaobd View Post
    Have someone tried to install and use these softwares with win7 x64 by installing some of virtual machines, dual boots or sth like that? did it work? any experience with that?
    and of course....man you are amazing
    http://www.digital-kaos.co.uk/forums...ws-7-a-114442/
  10. #280
    maaxxyy's Avatar
    North Pole
    Finally updated both pp2000 and lexia. Many thanks to SCARYMISTAKE and all who helped me. Great post !!!!!!!!!!!!!!!!
  11. #281
    Nov 2009
    Quote Originally Posted by fusername View Post
    thanks very much indeed. however I have a problem. After all I make activation and it does well. But, I don't know why, the tool doesn't connect any car.
    By the way, the PC identifier code gives 0. Only 0. Anyway it makes activation. I wonder if the problem is about that 0... Because, my prior experiences tell me that PC identifier code is different than 0.
    I appreciate every much every helps coming for my problem.
    i have the same problem, identifier 0
    i have installed pp2000 on another computer and it works fine if connected to the internet or not
    what could be the reason for a value of 0 as identifier, also if i connect to the internet the identifier number is ok and i can activate it, but i can only use the pp2000 when connected to the internet
    if i disconnect from the internet and try using planet it needs activating again and i can't activate it because i have a identifier 0
    i need to use it when not connected when out and about
    any help would be appreciated
  12. #282
    Aug 2009
    Lithuania
    I noticed that "parameter measurement" function is unavailable after update? It worked perfect in my older version (20.14). What is the reason?
  13. #283
    Jun 2010
    Hi, I'm new here and I can not find the PP2000 lin***312;?w V22. Please help
  14. #284
    Top Poster Digital Auto's's Avatar
    Jan 2010
    Hi, anyone have V22.14
    Also does anyone have a working keygen. thanks
  15. #285
    Jan 2011
    Quote Originally Posted by rafiozo1 View Post
    Try this:
    Peugeot Planet 2000 v22.14 ? Free Software Download | AspGfx.com
