Now I uninstall all and re-install LEXIA-345 only. And the problem all goes on. Again activation is OK, again PC identifier code is 0, again no connection with cars... any more idea please?..
Have You deleted APPLIC folder from disc C after uninstallation? If not - uninstall it again, delete this folder and then do installation from beginning!
Cheers!
....by the way! Take search on DK. I think have seen something like that before here.....
the problem should be about the module. I will inform you if I can pass the problem with another module.
Download not available
The following download is not available:
http://rapidshare.com/files/41195287...6.68.exe.html0 KB
please new link.Thanks
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
http://www.digital-kaos.co.uk/forums...86/#post806086
Hi guys this is my second go at updating my lexia and pp2000, i'm running lexia 345 and pp2000 21.14. I need to install pp2000 v 22 first but i dont have it. Does anyone have a link for v22? Thanks
Hi !
I have a Citroen Berlingo 1.6 HDI.
Where can I buy an Clone Adapter to
connect the car to the Notebook and
use the Lexia 3 Software ?
Thank you !
Pom
Use search. I have created one post about that. It works with virtual box.
http://www.digital-kaos.co.uk/forums...ws-7-a-114442/
Finally updated both pp2000 and lexia. Many thanks to SCARYMISTAKE and all who helped me. Great post !!!!!!!!!!!!!!!!
i have the same problem, identifier 0
i have installed pp2000 on another computer and it works fine if connected to the internet or not
what could be the reason for a value of 0 as identifier, also if i connect to the internet the identifier number is ok and i can activate it, but i can only use the pp2000 when connected to the internet
if i disconnect from the internet and try using planet it needs activating again and i can't activate it because i have a identifier 0
i need to use it when not connected when out and about
any help would be appreciated
I noticed that "parameter measurement" function is unavailable after update? It worked perfect in my older version (20.14). What is the reason?
Hi, I'm new here and I can not find the PP2000 lin***312;?w V22. Please help
Hi, anyone have V22.14
Also does anyone have a working keygen. thanks
