Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 111
Thread: VCDS 10.6.0
    Member lovelyirshad's Avatar
    Default VCDS 10.6.0
    HERE YOU GO FOR VCDS 10.6.0 and the password is lovelyirshad75
  2. The Following 6 Users Say Thank You to lovelyirshad For This Useful Post:
    Electrode (13th July, 2016), GLOCK19 (21st March, 2019), jeffy1978 (6th June, 2018), liviud (10th December, 2016), ruug3r (4th January, 2017), tolisnancy (1st October, 2018)
  3. #2
    z786's Avatar
    10 Steps Ahead of You
    clone or original soft?
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    i got from my friend he said its clone but by my self i didn't check
    cipijoint's Avatar
    Ross-Tech: Home , ever heard about that?
    dont talk a lot and nothing
    H? mate , this cable VCDS 10.6 is good ?
    Thanks.
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by jo?o antonio View Post
    Thanks.
    Yes its VERY GOOD if its original one, used on Vag Cars only.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    VCDS rules
    Member Icemaan's Avatar
    Quote Originally Posted by jojo1212 View Post
    VCDS rules
    True
  10. #9
    DK Veteran KenshinPT's Avatar
    PT
    We want the dump, not the installer!
    The installer is available free from Ross Tech.
    Or..... Is this a modified installer and I can use it on my 908.0 clone cable? I don't think so.
    Did it help? Push Thanks below
  11. #10
    BiH Kiseljak
    does it work with cloned interface 908 or we need to change dump inside interface ?
  12. #11
    UK
    I think it needs to be made clear, is this a fixed version for older clones. As above the software is freely available from RT.
    MBP
  13. #12
    Top Poster baner's Avatar
    Default VCDS VAG1006 clones dumps, anyone?
    Quote Originally Posted by pecirepi View Post
    Does NOT WORK, checked by myself on chinese cloned VAG908 and VAG912 cables, HW ver 1.81.
    Software installs fine, drivers also, but when cable IS PLUGGED INTO CAR, software says: "Port found, ... not plugged into the car!".!!!!
    So, what we really need here is FTDI and probably ATMEGA dump from VAG (VCDS) 10.06 chinese cable!
    If someone has it, please share it!!???
    Regards and respect!
  14. #13
    Top Poster + randomlog's Avatar
    Argentina
    Hi, thanks for everything.
    I test this soft but,, doesnt work, i tried with 908 and 912 chinese cables and get the same error of baner, all ok but "Not plugged into a car!".
    i tried with all 9XX drivers and i cant make work.
    i've the original chinese software minicd with vag 908.1 and 912beta but these versions also doesnt work.
    PD: zorry for my English.
  15. #14
    DK Veteran bibkare's Avatar
    B & H
    Quote Originally Posted by randomlog View Post
    By checking that soft you killed your interface, it will not work with any version, don't bother
  16. #15
    Argentina
    Quote Originally Posted by bibkare View Post
    oh, so i can burn vagcom cables and kill my provider.
    I've 3 cables 912... i'll check on windows xp virtual machine.
    (at least one must work?)
