Page 6 of 8 FirstFirst 12345678 LastLast
Results 76 to 90 of 111
Thread: VCDS 10.6.0
  1. #76
    xoom's Avatar
    Ylakiai
    i have 1.83 Flash side and it works with 912.
    but don't have eeprom for 10.6 :/
  2. #77
    italy
    hi, pardon the intrusion I wanted info on vcd 10.6.0 you can install the cable 812 vag?? thanks to all ..
  3. #78
    DK Veteran sroka's Avatar
    Oct 2010
    thanks for vcds
  4. #79
    Quote Originally Posted by xoom View Post
    do you have the EPT file?
  5. #80
    xoom's Avatar
    Ylakiai
    i use same as 805 ept file.
  6. #81
    my version is 1.81, i am guessing this is in the Atmega chip?
    thanks in advance
  7. #82
    xoom's Avatar
    Ylakiai
    Yep. it is.
    p.s. Aminebot words is interesting for me
    Last edited by xoom; 15th October, 2010 at 04:29 PM. Reason: it was little bit agains rules ;)
  8. #83
    if yours is 1.83, can you copy the atmega?
    sorry for the questions but don't know how this cable works.
  9. #84
    Oct 2008
    On Earth
    Hi mates
    Anyone has this softwear 10.6.0 cracked for chinese clone.
    I bought one and it is 1.81.
    The softwear provided by the supplier become unregistred.
    Thanks in advance.
    Good luck
  10. #85
    xoom's Avatar
    Ylakiai
    @mattydr67
    but maybe everything works well ?
  11. #86
    from my tests I see the following: does not work reading on channel 000 in the engine ecu
    must show all meas. parameters
    But no one else wants to check it in 908 and Chinese 10.60 ...
  12. #87
    xoom's Avatar
    Ylakiai
    Hmm i downloaded 10.6 from other thread.. installed but it doesn't start.. always error that cable not fount code=-2
    i tryed in FT change PID from FA20 to FA24.. nothing..
    (cable with FT232BL)
  13. #88
    DK Veteran bibkare's Avatar
    B & H
    do you use atmega eeprom from 908 dump also can your flash file be used with pcb with ftdi232b or only with 232rl
  14. #89
    xoom's Avatar
    Ylakiai
    Yes, it is with 908 eeprom.. i tryed just with 232BL..
  15. #90
    Oct 2008
    On Earth
    @mattydr67
    In the mean time I figure it out what was the problem that the sw becomed unregistred.
    I shuted down the sw and I run it again and in this moment the sw it was unregistred.
    You have to do this procedure everytime you run the softwear.
    It was posted here by the ipejasinovic
    1. Unplug device from PC and Car, turn off software
    2. Plug device into car
    3. Plug device into PC
    4. Run software
    Every time you run the softwear you need to do that.
    Everyting works well I haven't seen any bugs.
    Good luck
