Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    tried to find that commonlic.dll link but it said max out anyone else able to send me a link
    please
  2. #17
    impactops's Avatar
    Quote Originally Posted by smart.performance View Post
    please
    Extract it from the archive to C:\WINDOWS\zak\Starutils
  3. #18
    Replace 3 files /xentry06-new version/
    F:\Programme\Xentry\bin\india\ com.dcx.licencesupport.jar
    and
    F:\Programme\Xentry\bin\dlls\ CommonLic.dll
    and
    c:\windows\zak\starutils\commonlic.dll
    Restart
    And here it’s done
    I think i am really lost trying to get my xentry working and now lost what i copy these files for?
    i have xentry already loaded on my machine but needs a key to allow it to run
  4. #19
    impactops's Avatar
    mate this is only fo 3.2010, & u copy it in the directory i mentioned earlier
  5. #20
    thanks impactops i have done that what do i need to do now?
    sorry my head is cooked now are you on skype to ask questions?
    Last edited by smart.performance; 15th September, 2010 at 04:36 PM. Reason: to add request for im addy
  6. #21
    i have 03/2010, i have copied it in the directory you said and i tried a universal key gen and it would not go in, and if i try xentry it says contact star help desk?
    what could i have done wrong?
  7. #22
    impactops's Avatar
    can u provide screen pics of the error?
  8. #23
    antonypaul's Avatar
    Daer m8,
    The same way i done this xentry now its work in my system but need time fix
    thanks in Advance
    Antony Paul
  9. #24
    Quote Originally Posted by vigo4d View Post
    Please try this solution:
    Xentry Hang Solution Fix:
    If you install Xentry with a normal Xentry key (not a developer ) everything should install fine however sometimes it doesn't (in my case)
    What should you do?
    When Xentry setup copies the files to:
    F:\programma\xentry directory, you should open the directory F:\programme\xentry\bin
    There are 4 files: userconfig.xml, userconfig.xml.ja, userconfig.xml.ko and userconfig.xml.zh.
    Just rename them during the copying of the files and the installation will continue fine.
    Step 1:
    Copy DLL: c:\windows\zak\starutils\commonlic.dll(the dll is in the starutils folder).
    Step 2:
    Run Star Utils and the Xentry keygen, genarate then Save the key.
    Step 3:
    Go to DAS DVD: stardiag\InDia_Frame and run setup.exe (for Das 2010, the folder name is: Xentry_frame.
    Step 4:
    Click setup then installation completed.
    Step 5:
    and
    and
    Restart
    And here it?s done
    Can anyone tell me where can I download com.dcx.licencesupport.jar file to replace mine ?
    Thanks a lot
  10. #25
    Quote Originally Posted by wsc View Post
    i think this will help some of U,
    is the before and after installation
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
    Also i have post (#8) Xentry User ,delete the 4 userconfigs a litle before the installation complete
    Can you reupload please ?
  11. #26
    DK Veteran wsc's Avatar
    GR
    Quote Originally Posted by rabizone View Post
    Here M8
    http://rapidshare.com/files/421888000/Xentry_User.rar
    and
    http://rapidshare.com/files/42189797...stallation.rar
    Smart car engineer ,
  12. #27
    Dec 2010
    please I need help , i tried many times to install Xentry 11/2010 :
    System : Windows XP SP3 - Vmware .i used Zolokas Guide
    every time i try to install Xentry , it start till installing Windows SP3 files , then restarting automatically without contenue .
    please let me know what is problem and How can solve it?
    Thank you.
  13. #28
    hy guys!
    I need your help! I installed DAS 07/08 2010 from original DVD from MB. Everything worked great, DAS opens up, and works!! Now I wanted to install the extended Version (Xentry), i've done that a few times, but this time installation cancels, because I do not have a valid license key for xentry. Ok, i do have a keyGen for that, but in star utilities, there is NO ENTRY for Xentry Diagnostics!!! Only for DAS and WIS?? Why that do you have an idea? I tried to place the modified commonLic.dll to the right place but sill no entry for xentry ; (
    please help me!!
    When i click "OK" to go on with installation, it cancels completely!
    best regards
    MiloNiko
  14. #29
    thanks for support ; / may I am in the wrong thread! For all people who want to know what the issue is: WIN7 makes troubles! As I said, DAS works fine, Xentry is not able to read the hardware ID, thats why the item in the star utilities program is missing ; ( I installed XP (that was not my plan ; / ) and now It is working - but XP is so slow win 7 is much more better!!! I wish i could run it in win7...
    bye
  15. #30
    is there no DAS XENTRY pro out there? ; /
