Could you give me a link to DAS and Xentry installation package, please? Also, What is a developer mode?
hi
can somebody provide startkey for DAS 07/2010
XENTRY :
HW-ID 5EEABC30221C
AppID 252
Please StartKey.
Thanks.
Please xentry developer key
HW ıd 416C40C96DC4
APP ID 252
Thank you my lonely xentry 7\2010
No Developer mate, use this fantastic NEW tool that Patrian has come with, cause without it we would all be Doomed!!!!
http://www.digital-kaos.co.uk/forums...l-tool-161680/
Please generate startkey for developer Xentry 05/2008
Lan ID: 080052846937
@ impactops
please can you give me advice for my problem posted on page 16?? I-don't know what else i can do - I hope that there will be a solution without new install!Xentry normal tool seems not to work (Invalid ID) or i'm just too stupid for id :-(
enjoy and have Fun
Tom
If you are using 7.2010 then u can only use original key below
ZRDTG5XSB3FMPP4P2KJYGZKLSMFWH7TCX8CWXYEQDNUTY6SU7L B2MSUF6MA7E6WBTCLSEG7WWPXT4GCL9QAXZG3GL6DG8KQK9HWS 5ZEH5DEUTGWHXK3BGP98KUKQGU52M6GDLQS
You must also change your AppID to display 250 or you will get wrong AppID error.
To do this you must chnage the registry key setting from Compact4 to Compact2 so that when u run startutils it displays 250 in the AppID then You enter the Key above.
If you still get an error then Delete this file Lic_key2.dat from C:\Documents and Settings\All Users\Application Data\LicDir and enter the key again
Remove space from Key before entering
Hi, im running 0609 and chance some awsome person could supply me key for said version?
HW-ID - 5C9707503D3F
ApID 252
Thanks in advance.
@ impactops
Thanks a lot - you're the man!!
great instruction and all works fine!!
enjoy and have Fun
Tom
Xentry NORMAL:
You need the "Classic" Mod CommmonLic.dll & the Key WITHOUT Spaces!!!PHP Code:
ZVMZ2QC9VKMR5VNGLHVUMRL82K3LKLTTWAENLHN5PPTNSDT2Z3RMMM2FYQT56F28JHYEEXJLGJLJTHDX5SQRK6WC3SD3CBT4E97Z5NQ7DPSGSRFYGT6J3TCBSLN9XM88YN
IF you interest about the Developer Mode you can use the Demo-Universal Shity Key.....
God Luck!
Regards!
PS
About W204 via DAS the Version that you have, working WITHOUT any Password!!!
IF you trying something in the Air-Bag module for example, this is 1 OTHER story.....
BUT and for this existing solution!
USE the ICAB Calculator!!!![]()
