Page 2 of 334 FirstFirst 12345671252102 ... LastLast
Results 16 to 30 of 4996
  1. #16
    Quote Originally Posted by engine View Post
    Can some one generate DAS and XENTRY dev KEY 03/2010 FOR THIS lan id DAS:
    080097DF038F
    XENTRY :
    AppID 252
    HW-ID : 599F6E8AE64B
    DAS Dev: *1rr50ztk24vm1f3hymdfhhtz3jgkmzrryqu0pdl0vtkv4
    Don't forget to thank when someone helps you!
  2. #17
    Quote Originally Posted by flyguyvan View Post
    i have DAS 8/2008. can someone walk me through how to enable DEV? thanks
    Tell your lan id and someone will generate you a Dev key...
  3. #18
    Can some one generate XENTRY dev KEY 03/2010 FOR THIS lan id DAS:
    XENTRY :
    AppID 252
  4. #19
    chakahafed's Avatar
    nouakchott
    Quote Originally Posted by Patrian View Post
    Well, I am still here.....
    Now.....
    Because i think you Upgraded your WIS/ASRA or something like that, Re-install ONLY Xentry 3.2010
    and replace again the files as you know when installation finish.....
    Also, FOR SURE you need to use the Timeout Fix for to run Xentry!!!
    Good Luck!
    Regards!
    WELCOM BACK PATRIAN
    yes as you sade i have upgraded wis net from 03-2010 VER TO 07-2010 so just after that wis don't work and XENTRY too! i am installing DAS NOW and check if yourk !
    thanks patrian !
    regards
  5. #20
    Quote Originally Posted by chakahafed View Post
    WELCOM BACK PATRIAN
    thanks patrian !
    regards
    Yeah that's the problem, sometimes replace the CommonLic.dll in System32 may work but sometimes not.
    So I prefer to install EWA net instead of WIS net standalone, this won't ruin the Xentry but no interlink to WIS.
    Cheers
  6. #21
    DAS 08/2008
    LANid:
    0800018b41b7
    can you walk me through how to input this dev key? thanks
    and once i enable dev mode, will all my menus be in german?
  7. #22
    DAS 08/2008
    LANid:
    0800018b41b7
    This is your DAS Dev key: *1rr50ztk24vm1c5f3fxvhhtz3jgkmzrryqu0pdl0vt5ui
    Open Star Utilities, then Startkey Manager and choose DAS. Replace your old DAS key with your new DAS Dev key and save.
    Start DAS, press F2 two times, choose Cars, press F3 and you will see a warning message written in german which tells you that you have Developer-mode activated.
    Only additional developer menus will be mostly german, everything else remains like before.
  8. #23
    chakahafed's Avatar
    nouakchott
    Now.....
    Good Luck!
    Regards!
    it's worked
    thanks and dont leave us
  9. #24
    XENTRY :
    AppID 252
    gl
    this is your key
    Xentry Dev : 2ETG5SAV6XVKWN25Z4EB672D9S5XCMLWVWDRGXHGS5AJH6DLMV Q43YVBXEHJLSXE4NH64KFLYG67YVGG9VEHYM7P27PYCJRCRX3P H3695J2V776SVVNTEXSBZUNNQJ6HE2
  10. #25
    DK Veteran cocoh's Avatar
    Jun 2009
    Quote Originally Posted by nguyennhatquang View Post
    gl
    this is your key
    XENTRY :
    AppID 252
    Please try this and tell me what do you see!!!!!!
    App: 252
    MEMCJRHN457RX8A7SNY8FM2NNLKSANHSBAVFB2Y75PCFE7RBSW UQNH6WPCTYQNBG5RYEB8B648B3CVXR86VXR284W8LMFR56VZEV WRMPJ5EMBHUZNWZNDLRZS9QLLTWQZJ
  11. #26
    Quote Originally Posted by Timppasa View Post
    i dont see any additional menus
  12. #27
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Read carefully what Timppasa has written to you and see the pictures I am attaching .
    In the third picture you see it highlighted in yellow
    and then further down on choosing different menus on picture 4 you see selection development data also highlighted.
  13. #28
    Quote Originally Posted by gmatj View Post
    and then further down on choosing different mens on picture 4 you see selection development data also highlighted.
    Sorry picture 4 is attached in this post - Development Data selection
  14. #29
    Can some one generate XENTRY dev KEYTHIS lan id DAS:
    XENTRY :
    AppID 252
    HW-ID : 5EBA4204B273
  15. #30
    i DO see the development kit warning screen like yours in the screen shot #3,
    but i DO NOT see development data in the next screen. i will post screenshot soon
    note: i am running DAS 08/2008.
    if anyone can provide updated DAS/xentry/wis/star, please pm me
