Page 4 of 334 FirstFirst 1234567891454104 ... LastLast
Results 46 to 60 of 4996
  1. #46
    Oct 2008
    Greece
    Question
    Quote Originally Posted by gmatj View Post
    Das Developer : *1srt0ztk24vm0mv2hdxvhhtz3jhwm4obyxuwqij0vqmf0
    Hmmmmmmmmmmmmmmmmm.....
    My FULL & Developer Key for him:
    *1rrt0ztk24vm0mv2w0xvhhtz3jgwmyobyrw0qaksvrar0
    1st "Episode" you think George?????
    Regards!
  2. #47
    GB
    Hi Patrian
    Is your tool the final one or the one that does not communicate with the car.
    wbr
  3. #48
    please i need das dev key:
    land id 0800A0B229E1
    XENTRY : 0790CDA0FB2F APP ID: 250
    THANKS.
  4. #49
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Quote Originally Posted by dieselequipos View Post
    THANKS.
    DAS Developer : *1srt0ztk24vm1ypthdxvhhtz3jhwm4obyxuwqij0vsble
    Enjoy
    P.S. Xentry for what version ???
  5. #50
    xentry 07/ 2010
  6. #51
    xentry 07/ 2010
    Not yet !! - Stay around
    In the mean time you can use 2010.01 or 2010.03 which are all tested and working perfectly.
  7. #52
    Quote Originally Posted by Patrian View Post
    Well, I am still here.....
    Now.....
    Because i think you Upgraded your WIS/ASRA or something like that, Re-install ONLY Xentry 3.2010
    and replace again the files as you know when installation finish.....
    Also, FOR SURE you need to use the Timeout Fix for to run Xentry!!!
    Good Luck!
    Regards!
    Sure! I confirm with Patrian step and do not forget replace modify commonlic.dll.
    Good Luck.
  8. #53
    i have the 08/2008 version, anyone know where i can get the 2010?
  9. #54
    Junior Member Alexny1's Avatar
    New York
    Default Need all DEV keys, Compact4 all keys blank
    Hello I need DEV keys for DAS, Xentry, And WIS if possible.
    I have Compact4 that was not updated for about 1 year maybe a little more. It has no key licences right now.
    LAN ID 0800034BE7A5
    AppID 250
    HW-ID 1138560F6B33
    I want to try to install 5/10 or 7/10 what ever works.
    Thank you
  10. #55
    Member bigdiez's Avatar
    May 2009
    south germany
    If you need DEV use version 01/2010 or 03/2010
    or
    wait anymore and stay around ;-)
    3 posts above:
    reading...reading...reading
    P.S. what a wonderful beginning post...
    I NEED ALL....
    no more to say
    Lower the head of your hard disk drive....increase not the acess time of your hard drive !
  11. #56
    New York
    Not a lot of help from bigdiez
  12. #57
    Aug 2010
    land id 080095644754
    Thanks.
  13. #58
    Quote Originally Posted by Alexny1 View Post
    Alexny1
    Bigdiez gave you very good advice and you should thank him. 2010.01 and 2010.03 work really good and are fully tested.
    If you want to go into trouble go further down the road and Good Luck.
  14. #59
    Quote Originally Posted by fagor View Post
    Thanks.
    Here it is
    *1srt0ztk24vm0tefhdxvhhtz3jhwm4obyxuwqij0vrxxi
    Enjoy
    P.S. And do not forget to press the Thanks key !!!
  15. #60
    Aug 2010
    Thank you for the key, DAS working with older machines.
    but the new machines not working (for example E-class->210->210.061). Error (1.2)-2.503.13003
    DAS install over DAS 03/2010
    (Sorry for my bad English )
