Page 83 of 334 FirstFirst ... 3373787980818283848586878893133183 ... LastLast
Results 1,231 to 1,245 of 4996
  1. #1231
    Feb 2011
    Almeria, Spain
    Quote Originally Posted by Timppasa View Post
    DAS Dev: *1rr50ztk24vm0tgtfrxvhhtz3jgkmzrryqu0pdl0vssze
    Thank you very much for the help and answer.
    I'll try the serial for the DAs developer.
    But what is the key to Xentry developer.
    I need to use the version Xentry 10.2011
    Greetings
  2. #1232
    Feb 2011
    Need a code for Renault clio tuner
    Model no:22DC258/62B
    RN258F10061381
    Prod No:FD0101250061381
    8200057673TZ791
    Please help...
  3. #1233
    Member LeviDenim's Avatar
    This thread is for the Mercedes Star system software. Not sure if you get a Renault code in this thread.
  4. #1234
    Nov 2010
    Default special function passwords remove
    if I installed das developer full will it continoue to ask password for special functions how I can find pass generator for it or disable that. there is a lot of developer mode passwords I find a pass generator it says developer full developer advance developer safe .... which one you recommend me to install or anyone can remove passwords
  5. #1235
    DK Veteran Mackhack's Avatar
    Quote Originally Posted by chemicalunal View Post
    You will need to buy a keygen for those passwords. Some sell them for 330 Pounds, others sell a cheaper keygen for 150 Euros.
  6. #1236
    Feb 2011
    Cool Why is not possible to save Xentry key in 11.2010 ?
    Why is not possible to save Xentry key in 11.2010 ? DAS key ok, Xentry can't be saved in das 11.2010
  7. #1237
    Hi, friends.
    My trouble is not open Wis net standalone from DAS.
    Maybe wrong key.
    My LanID:0800C600F253
    I need dev key for DAS 11/10 and
    Wis net standalone 11/10
  8. #1238
    Can I have a DAS code for :
    DAS 11.2010
    Lan ID: 08009C8C94A7
    Thanks a lot
  9. #1239
    DK Veteran yuuki's Avatar
    Nov 2010
    Japan
    Quote Originally Posted by Olegc200k View Post
    Hi, friends.
    Maybe wrong key.
    DAS=*1rrt0ztk24vm1lbihcgfhhtz3jgvtgoohjdgphl0vqepw
    WIS=*1rrt0zsz24vm1lbihcgfhhtz3jgkmyobyquzqyd0vqixw
    Good Luck!!
  10. #1240
    Nov 2010
    Japan
    Quote Originally Posted by zimbali7840 View Post
    DAS 11.2010
    Thanks a lot
    DAS=*1rrt0ztk24vm1a0obhlfhhtz3jgvtgoohjdgphl0vqgcu
    Good Luck!!
  11. #1241
    Quote Originally Posted by yuuki View Post
    Good Luck!!
    Thanks a lot, but DAS say WIS not exist in this system.
    Xentry start wis net without trouble.
    What can I do?
  12. #1242
    Thanks for all.
    All works fine, trouble is wrong lic.sli.
  13. #1243
    The same problem on my C4.
    I need DAS developer key for 11/10
    and WIS net standalone 11/10
    LANID: 08002DEC5CC
    Thanks a lot.
  14. #1244
    Dec 2010
    LANID: 08002DEC5CC
    Thanks a lot.
    Something is missing, no? ))
  15. #1245
    To avoid creating a new topic I've a question: Does DAS simulation for W204 cars work for you? I've try it with several DAS versions and I always get the same error message:
    "IP0: skip if statement because of invalid expression!"
    "IP0: skip handlerfunction funtion 'N_StrLen' because of invalid parameter!"
    Best Regards
    EDIT:
    I found that the problem is the impactops lic.sli. When I use the lic.sli from zoolokas guide, i don't have that problem.
