Hi!
I have exported .bin file from .dim file which I read with BDM100, modified it and now can't understand how to convert it back into .dim
I use DimSport software fnd there is only Export button...
Thanks in advance
Hi!
Thanks in advance
Programm for BDM-100. Click import, open file and import...
Hello Anzelmas,
I came accorss the same problem. Have you managed to sort it out?
just play with the marker zone wich dim put it at the beging, copy paste using a hex editor will do the job...
I need to convert bin back to dim. Anyone could help? using bdm100
