Results 1 to 8 of 8
Hybrid View
    Anzelmas's Avatar
    Nov 2009
    Stockholm, Sweden
    Default How to import .bin file back to .dim?
    Hi!
    I have exported .bin file from .dim file which I read with BDM100, modified it and now can't understand how to convert it back into .dim
    I use DimSport software fnd there is only Export button...
    Thanks in advance
    Dec 2009
    Programm for BDM-100. Click import, open file and import...
    Dec 2010
    Hello Anzelmas,
    I came accorss the same problem. Have you managed to sort it out?
    Top Poster otzi's Avatar
    Dec 2009
    Austria
    Quote Originally Posted by Anzelmas View Post
    Hi!
    Thanks in advance
    Hello
    A dim file I can import file bin file but not impossible to dim
    I work with dimmsport
    BR.
    DK Veteran rappttor's Avatar
    Apr 2010
    PERPETUUM MOBILE
    just play with the marker zone wich dim put it at the beging, copy paste using a hex editor will do the job...
    Oct 2015
    BRAZIL
    I need to convert bin back to dim. Anyone could help? using bdm100
    Jan 2020
    UK
    Did you work out how to do it? I am in the same situation.
    Hi!
    Thanks in advance
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Quote Originally Posted by Ampy View Post
    The solution is to convert BDM100 to work with CMD software...
    Good luck!
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
