Results 1 to 8 of 8
Thread: VCDS 912beta
    Default VCDS 912beta
    i have vcds 912beta china clone and works good.
    can anyone tell which immo-soft run with this cable???
    i need immo-soft to read pincode
    many thanx
    VCDS interface doesn't support reading of pin code. I saw one method, probably in Bosch dashboard that someone read the pin code by VCDS, but it was complicated. You should buy Vag Tacho USB, Vag K+Can Commander or another interface which is dedicated for pin code reading.
    Quote Originally Posted by dieseltechnika View Post
    where did you bought this clone?
    Junior Member jonesy118's Avatar
    yes, as mentioned, you must use something like VAG TACHO to read SKC. I found this out, when I came to programme a new flip key to my car.
    use VAGTACHO to read SKC, then VCDS/VAGCOM to adapt and relearn the number of keys!
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by jonesy118 View Post
    Jonesy118 Cant you think of your own signature, you've copied Drakov !!!!!!!!!!!!!!
    Liteace's Avatar
    Mar 2009
    On a rock
    That was quick you soon got rid of that
    Top Poster georgegt's Avatar
    Romania
    VCDS is a clon from retail VCDS Ross Tech and is only for diagnostic and configuration
    U can't use this interface with other programs
    does anyone know if vag dashk+can can read immo-pin from seat alhambra 99 und golf 3 97?
    i?ve tried can commander and it doesn?t work
    Quote Originally Posted by georgegt View Post
