Results 1 to 12 of 12
    Jan 2010
    Default Passat 2007 dashboard change
    Hello maybe can give me some advise.
    A friend of my has buy a import usa vw passat 2007.
    Now everything is in mileage and it should be km. Now he will buy a new dash.
    The Vw dealer ask a lot of it to let it work.
    I will help him, but I don`t know that i can.
    I think i opened his usa dash and read the eeprom, and write the dump into the new dash.
    But i`m not sure that this is the only thing I have to do.
    Can someone give me a advise before i`m starting something stupid...
    Dec 2009
    Do not write the eeprom to the other dash. It will not work and show error.
    You can adjust km with rosfar or via OBD with any tool that can handle VW dashs after 2006.
    Change coding with VCDS/Vagcom.
    Jan 2010
    I can adjust it by obd with my usa prog from smelecom.
    But i think whit a new cluster the car won`t start because the immo.
    Dec 2009
    Land of Rocks
    The car will start. Passat B7 doesent have the immo in dash. For swapping the dash is a matter of adaptation with car. VIN , coding and others.
    Jan 2010
    Does that mean, that when you changed the cluster, the car is starting, and you only have to changed the mileage by obd and that is all ???
    Dec 2009
    Land of Rocks
    But why do you want to change the dash? Original can be coded for all you want to see on it.
    Jan 2010
    He want a original eu dash.
    He and me, don`t know how we can change that.
    I have no idea how it can be changed from miles/h into km/u.
    Dec 2009
    Land of Rocks
    Quote Originally Posted by gijsvm View Post
    With VCDS. Instruments/Coding
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    when you click on module 17
    go to coding
    and there should be help text, you jus hav to change 1 digit, job done
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Dec 2009
    He wants to change the dash because of the scales. that cannot be done by coding
    So normal EU dash will work out of the box with the car. Just do the coding for service intervall and things like belt warning, wisher fluid, brake indicator and so on.
    No VIN is stored in this dash.
  11. #11
    Jan 2010
    I have a old program vag com and try how it works by my own a4 2004.
    I get connection go to 17 instruments and see that recode is there but need a login 11.
    How can I get these code ?
  12. #12
    Dec 2009
    For changing the coding you don't need to login.
    There is a generic login code for adapting the KM via adaption channel 9 if km is below 100km.
    It is 13861
