Results 1 to 13 of 13
Thread: Capture Cards.
    Now that would be telling.
    Default Capture Cards.
    Hello ive been looking on ebay and i have seen this capture card, although i think it is.
    would i be able to record some of my games on the xbox of this?
    and i have just been looking at it there are the usual red and yellow wires but what are the other 2? and are they needed?
    NEW USB CAPTURE CARD VHS TO DVD S-VIDEO XBOX 360 PS3 on eBay (end time 11-Sep-10 12:54:20 BST)
    thanks in advance
    The statement below is False
    The statement above is True
    Which one is correct
    I am the fish geek
    V.I.P. Member chroma's Avatar
    Feb 2009
    Just outside of Glasgow
    480p signal at most captured and the comb filter on em is garbage so the composite (yellow phono plug) winds up suffering.
    It will do the job but dont expect high def or good looking results.
    He who laughs last thinks slowest.
    what quality will it be?
    I am the fish geek
    Nov 2008
    Quote Originally Posted by cM iPro v3 View Post
    thanks in advance
    red and white are audio left and right
    yellow is video
    the other is s-video
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    Your better of with a dazzle capture device
    how much more are they? is the s-video cable needed?
    I am the fish geek
    Nov 2008
    you can either use the svideo or the phono (yellow)
    If your device has a svideo out then use that as better quality but if not just use the yellow phono. Whatever you use you will need to use the red and white if you want audio.
    I think the quality you will get with the item in op will be similat to vhs quality.
    Feb 2009
    S-Video is dual chanel in that it supplies a chroma and luma signal seperately.
    Composite is single channel in that it supplies them both mixed and they need to be filtered apart. which is where the comb filter does its job.
    With video gear its a truism that you do get what you pay for, cheap tat will produce cheap results.
    The quality will be less than stellar with this device.
    ok is there any people would reccomend me?
    I am the fish geek
    Nov 2008
    modsvilla
    dazzle ones seem to be the ones people use more,there are setup vids on utube etc but my son lewimel knows more about it all because he as done 100`s of xbox recordings i will let him know about this thread but is in blackpool today....micky
    ok thanks mate
    I am the fish geek
    Newbie Lewimel's Avatar
    Lancashire
    Hey. this might work but i wouldn't risk it, you're better off with a dazzle, they are great quality if you get the right one and set it up properly, im actually currently tryin to flog mine, ive deleted all my videos off youtube so you cant see the quality but i still have some on my desktop if you want me to put them on filefront so you can see the quality?
    Lewimel
  13. #13
    Lancashire
    also s video is not needed with a dazzle
    Lewimel
