Results 1 to 3 of 3
    Unhappy transporter dash fault
    Hi All,
    Have a strange fault with a 1998 VW transporter.
    Has recently had a new engine fitted.
    All ok until 6 months after, it now has a perculiar
    fault with the dash
    ignition off mileometer on
    ignition on mileometer off,no glow plug lamp
    or gauges.
    customer reports when driving intermitant speedo
    and gauges when all is normal a alarm similar to
    a reversing beeper sounds.
    Also whilst doing some suspension work the battery
    went flat(nothing left on)
    at a bit of a loss as where to start to look.
    Customer has had a lot of subsequent faults after the
    engine was fitted which is where i came in to sort things
    out,all other faults(non electrical) now sorted.
    A good one for all you VW experts!!!!!!
    Thanks in advance,
    Steve
    Liteace's Avatar
    Mar 2009
    On a rock
    Has it not got DLC so you can vag-com it, I know its a 98 but my 96 Golf TDi has DLC, sound like an earth problem
    Liteace's Avatar
    Mar 2009
    On a rock
    Transporter (RHD) 96-98 left hand side of steering wheel under flap 98> under steering column
