Results 1 to 2 of 2
Thread: vauxhall omega
Hybrid View
    Default vauxhall omega
    2002 reg, omega b, 2.6 airbag warning light keeps coming on,plugged in comes up with code 89 front passenger side airbag module malfunction, i have checked wiring all seems fine ,even soldered the connector next to the seat,is there a seperate sensor for this or will it be srs module which is at fault, it as side seat airbags as well. thanks
    Quote Originally Posted by radiosolutions View Post
    There is a side airbag sensor (P72) within the passenger door,remove door trim to access,two wire connector to sensor,one wire white,one wire brown/white.check connector and pins for corrosion and loose fitting,also check connector X12 ,main connector between door and car.water ingress here can cause high resistance and incorrect readings,the connectors underneath the seat have no relevance to this trouble code.If all connectors are ok ,disconnect K31 airbag ecu connector and P72 side airbag sensor and battery and check for high resistance on the wires from sensor to ecu,If wiring checks out replace P72 sensor first then ecu if fault still there.
    Hope this helps
