Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: DAS HHT-WIN
    Default DAS HHT-WIN
    my das complete setup....so tired!
    thank you winhex to find my code!
    but where is setup HHT-WIN?And i want to change language!
    anybody help me please!.......many many thanks
    DK Veteran bibkare's Avatar
    B & H
    You have already installed hht, to change language you need to open file hhtwin.ini, it is located in c:\windows and erase every line that has scn letters, you save that ini file and after when you start hht you will be prompted to choose language. I am writing this from memory cause actually i don't have any DAS installation at the moment so i am not able to tell you exactly
    B & H
    Sorry i misinformed you, i checked in my notes and this is what you need to do: Go to C:/Windows/hhtwin.ini and delete these lines!
    SPC=02
    SPCN=02
    SPCP=02
    SPCD=02
    SPCV=02
    save that ini file and that is it
    Member stefan's Avatar
    Quote Originally Posted by bibkare View Post
    SPC=02
    SPCN=02
    SPCP=02
    SPCD=02
    SPCV=02
    He does not have to delete these lines. He want to change the language of HHT.
    Just change the numbers. "02" stands for english. "00" stands for russian.
    There was complete list of these numbers in the old forum.
    00 for russian?
    or miracles happened?
    If yes ,..ditex rulez!
    France
    Default language
    05 is for portuguese
    cipijoint's Avatar
    026 for romanian
    dont talk a lot and nothing
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    012 is GREEK
    Isn't HHT accepting the first two digits only? I assume the mapping is the same as for DAS (redundant info below but the numbers appear too):
    al=C:\Programme\DAS\Thesaur\thesaur\000\thesaual.d bz
    de=C:\Programme\DAS\Thesaur\thesaur\000\thesaual.d bz
    gb=C:\Programme\DAS\Thesaur\thesaur\002\thesaugb.d bz
    en=C:\Programme\DAS\Thesaur\thesaur\002\thesaugb.d bz
    fr=C:\Programme\DAS\Thesaur\thesaur\003\thesaufr.d bz
    sp=C:\Programme\DAS\Thesaur\thesaur\004\thesausp.d bz
    es=C:\Programme\DAS\Thesaur\thesaur\004\thesausp.d bz
    it=C:\Programme\DAS\Thesaur\thesaur\006\thesauit.d bz
    jp=C:\Programme\DAS\Thesaur\thesaur\020\thesaujp.d uz
    ja=C:\Programme\DAS\Thesaur\thesaur\020\thesaujp.d uz
    us=C:\Programme\DAS\Thesaur\thesaur\002\thesaugb.d bz
    sf=C:\Programme\DAS\Thesaur\thesaur\010\thesausf.d bz
    fi=C:\Programme\DAS\Thesaur\thesaur\010\thesausf.d bz
    br=C:\Programme\DAS\Thesaur\thesaur\005\thesaubr.d bz
    pt=C:\Programme\DAS\Thesaur\thesaur\005\thesaubr.d bz
    tr=C:\Programme\DAS\Thesaur\thesaur\017\thesautr.d uz
    dk=C:\Programme\DAS\Thesaur\thesaur\008\thesaudk.d bz
    da=C:\Programme\DAS\Thesaur\thesaur\008\thesaudk.d bz
    se=C:\Programme\DAS\Thesaur\thesaur\009\thesause.d bz
    sv=C:\Programme\DAS\Thesaur\thesaur\009\thesause.d bz
    ko=C:\Programme\DAS\Thesaur\thesaur\023\thesauko.d uz
    cn=C:\Programme\DAS\Thesaur\thesaur\025\thesaucn.d uz
    zh=C:\Programme\DAS\Thesaur\thesaur\025\thesaucn.d uz
    cs=C:\Programme\DAS\Thesaur\thesaur\019\thesaucs.d uz
    pl=C:\Programme\DAS\Thesaur\thesaur\018\thesaupl.d uz
    gr=C:\Programme\DAS\Thesaur\thesaur\012\thesaugr.d uz
    el=C:\Programme\DAS\Thesaur\thesaur\012\thesaugr.d uz
    ru=C:\Programme\DAS\Thesaur\thesaur\022\thesauru.d uz
    ro=C:\Programme\DAS\Thesaur\thesaur\026\thesauro.d uz
    sh=C:\Programme\DAS\Thesaur\thesaur\027\thesaush.d uz
    hr=C:\Programme\DAS\Thesaur\thesaur\027\thesaush.d uz
    hu=C:\Programme\DAS\Thesaur\thesaur\021\thesauhu.d uz
    nl=C:\Programme\DAS\Thesaur\thesaur\007\thesaunl.d bz
    Default hhtwin language
    Hi All
    Does someone know which is the code for Spanish?
    Quote Originally Posted by acascarla View Post
    Hi All
    It is only one post above (#9) !!! - Just have a carefull look
    Quote Originally Posted by DB_member View Post
    Some language pack extension are dbz, others are dbu.
    Who knows what is the difference between that extension?
    Sorry OOT,
    And by what editor can I edit it?
    I try to make it for my country language that is not supported yet.
  13. #13
    Sep 2010
    Quote Originally Posted by gmatj View Post
    012 is GREEK
    no, you guys are getting carried away.
    hht does not support all these languages. if you delete the lines as bibkare suggested, you will see what languages are available.
    ( dont think there is anything there for the mods to want to delete, but I wont hold my breath )
  14. #14
    Quote Originally Posted by littledan91 View Post
    I never said all languages would be supported but one could easily interpret the list this way. Your clarification is well justified then.
    I was also about to mention your option (and bibkare I guess) to find out the supported languages. This can be found from the HHT folder too when looking at the numbers for different files that refer to supported languages.
  15. #15
    Not carried away m8.
    Greek is supported !!! and it is 012.
    In Thesaurus
