Results 1 to 6 of 6
    Jun 2010
    Netherlands
    Default Mitsubishi Colt 1,6 16v Rpm limiter
    Hello,
    Is there anyone who can help me to find the rpm limiter? I have a ecm2001 driver but when I load the driver and file I see no rpm limiter.
    Who can help me to a good ecm2001 driver or find the rpm limiter?
    Jun 2010
    Netherlands
    Is there nobody who can help me ????
    Hey dude, take it easy, it is been two days only since you asked.
    Your limiter is at location 4139h. There are two bytes, 02h, 26h (0226h = 550d). Divide 4750000 between that number (550) and your limiter should be 6800 RPMs real number, but 7000 with the variations of the analog tachometer.
    Good luck
    Jun 2010
    Netherlands
    Hello,
    Thanks for the quick help, but I don't understand how I tune a file with adress lines. I have added a ecm driver without an rpm limiter. Is there anyone who can help me to set this adresses in my posted file so i can see the rpm limiter when i load my file?
    Greetz
    Quote Originally Posted by zilog357 View Post
    Good luck
    I already corrected this in another thread. Doing the same here.
    The base number (divider) is not 4750000, but 3750000.
    The formula would be then 3750000/(MSB,LSB) Bytes.
    Regards
    Jun 2010
    Netherlands
    Regards
    Thanks that post is my another post here.
