This test image is not final
Do a factory reset BEFORE using this image
UR fixes
1.Improve VFD
1.1-added VFD micom version ("Front processor ver:") in About (old micom is "1.0.0", lastest micom is "1.0.1")
1.2-added resolution icon in VFD (480p, 576p/i, 720p, 1080i/p)
1.3-added mute, power, REC, SAT, Tu1, TER, TV and Radio icon in VFD
Note) VFD Icons not ready yet : FILE / TIMESHIFT / TIMER / HD / USB / Lock / Dolby / MP3 / REC (in File Play)
1.4 fixed time bug when standby
1.5 added character font table in VFD (some channel name was not shown in VFD)
1.6 added EXT. signal message in VFD when vcr mode select
1.7 improve deep standby (when standby mode, only navigation LED display)
1.8 improve standby
2. added TV/AV function
3. added VCR function
4. enable timer menu (but recoding function is not stable )
5. improve rgb, cvbs, ypbpr hardware level
6. fixed wrong Video format and Video size in Service info menu (info -> info)
7. fixed bug to work volume and mute in RCU when standby
8. fixed aspect ratio bug when source stream is 4:3
9. added automatic function in Aspect Ratio, when scart mode
10. added resolution mode (480i / 576i)
11. fixed radio background bug
12. fixed broken image when TV and radio switch
13. fixed wizard message bugs when first start.
14. fixed mute image bug when resolution change
15. improve hang-up issue (Positioner setup)
16. fixed RCU button functioning bug (TV/RADIO, TV/AV)
DW modifications
Rytek EPG installed
Rat's boquets installed (Sky UK 28.2E)
New boot screen
Improved CCcam Ppanel
Jimux Ppanel toolkit installed
CCcam.cfg reduced to only needed lines
Recording paths edited to point to internal HDD
Timeshift paths edited to point to internal HDD
Jimux audio player (wav files only)
*make a directory on your hard disk to store '.wav' files. Any directory name will do as it searches /media/ for '.wav's. Then just load a few 'wav's, run the option to 'Find Audio Files' (yellow button, 'ppanels', 'Music Jukebox' and you are ready to go.
Thanks to everyone involved in making these modifications possible
