Hi guys, I just bought c168 and found out that it is not the original but a clone.
I have trouble installing the software version 15.70. When I try to install it gives a message "error launching installer"
Can anyne help me please?
If you have a trouble with installing the soft than you have a trouble with soft and not with clone device.
Post here or upload to rapidshare your soft and I can check your software.
carbrain is ok,launch and autoboss very good
Miha99 thank you.. I downloaded the software you posted on page 1 and it works just fine. Now my problem is when I try to scan a car the software is checking the combox and it gives me a message "please contact with the dealer". Am I doing something wrong? Can you help?
C168 clone not support with original software c168.
Use software version 15.70
@Bram380 do you have version15.70? Is there a way I can obtain it? I'm getting really frustrated.
Hey yono what scanner do you use, Xcar431 ?
Jono5657 use c168 clone.
It's same as Xcar 431.
So not working with software v15.68.
Software v15.70 must be use for c168 clone.
Of course c-168 is avalible, but if you deside to buy low cost interface, than rader buy HXH scanner!
good friends someone I arraja the layout of the combox carbrain C168 and dump programming. and that mine broke and I do not know if the plug obd also not be in short circuit, I see it took a technician to see what is because the Chinese do not say anything and Grant nor ver.obrigado
But witch one is better.
Carbrain c-168 or HXHscanner.
Or is the one an improved copy of the other??????
Is there someone who had experince with both that can give his revieuw about the two?
Any news about the update 15.70 for the carbrain?
Finally, something got posted in the Carbrain (www.c-168.com) website download page. It's some beta version of Carbrain II. There are two files there:
Car Brain II 01203 Beta
Car Brain II 01129 Beta
These files install over your current Carbrain software in your computer. The 01129 Beta does not do anything and just hangs. The 01203 runs and turns out to be just a teaser/incomplete software. Barely contains anything.
Since this overwrites your existing installation. Better put a different directory/folder when you try to install it. So it installs on another directory. This thing is like a demo software. Not much in it. I guess they just want to show they are developing Car Brain II.
Per my opinion, it's worthless trying to look into this. But a positive note is, finally there's some movement in the website. The company is still alive.
